routing Turbo 350 lines
Wondering how the lines were suppose to be routed. Like a lunk head, I didn't mark how the lines were suppose to be routed and now I'm stuck guessing. I know the upper line on the radiator is the return and the lower is the trans to radiator. Just need to know where to hook up the lines to the trans. Does the return connect to the upper or lower port on the transmission?
6th Gen ('00-'05): harness with built in re-routing for alarm sounds
walkingonabullet
Oct 17, 2012 06:50 PM
BreakfastPirate
15
Apr 1, 2009 06:42 PM
