Replacing Bent Rod
Old Aug 23, 2012 | 11:03 PM
04chevyboy's Avatar
Default Replacing Bent Rod
Is a bent rod the end of the motor or what is needed to be done to get rid of this problem.im find gp's cheap that have bent rods an i could handle the task myself as long as it does not requier pulling the motor,any help would be great,thanks!
Old Aug 23, 2012 | 11:51 PM
Budsjlm's Avatar
You would have to pull the engine, becuase 9 times out of 10 your going to have crank damage
Old Aug 23, 2012 | 11:53 PM
A motor with a bent rod would need a complete rebuild.
Old Aug 24, 2012 | 07:51 AM
Franks 03SS's Avatar
2011 Monte Of The Year
Or you could get a donor motor and drop it in, but rebuild Would be better...
Old Aug 24, 2012 | 07:58 AM
If someone had a bent rod, I would just recommend getting a used block.
So if you are going to buy an engine with a bent rod, I wouldn't even bother.
Old Aug 24, 2012 | 01:46 PM
Just replaceing that 1 rod isnt going to work...It means that theres some other significant damage done to it....U need to rebuild the complete motor...Includeing line honeing the mains. etc... no other way to do it...other than a complete and different engine change...
Old Aug 24, 2012 | 10:13 PM
04chevyboy's Avatar
hmm,im not even gonna bother with the gtp's then,ill only need it for 1 winter lol
Absolutpolack
Apr 28, 2010 04:37 PM
dustybird3
Apr 14, 2009 08:30 PM
jhong292
21
Nov 25, 2008 09:07 PM
MC2K
Mar 24, 2007 03:17 AM
2whelfun
Jul 28, 2006 07:30 PM
