6th Gen ('00-'05): Random misfire and hard start
Old Oct 20, 2013 | 11:47 AM
JC Colon's Avatar
If you know were the MAP sensor is, the PCV valve is under it. When you remove the MAP, the bracket that holds it in also twist out like a headlight. But a little harder to move. Once removed the PCV valve is accessible. There is a spring under it that is re-usable. There is also an O-Ring. The new valve has a new ring.
The MAP and PCV sit on the right side of the intake Plenum, facing the car, above the belt. I don't have a pick. But I just put "location 02 Monte Carlo SS PCV. Valve" in my search engine image section. That's how I found it!
Old Oct 20, 2013 | 03:49 PM
CBredes's Avatar
On mine the pcv valve is right on top but it has riveted bracket so you can't remove it. I googled about this and it said that it was only put on the 2005 and its there so you can't put an aftermarket one one. Could I just cut off the bracket?
Old Oct 20, 2013 | 05:57 PM
JC Colon's Avatar
I January have to say, I don't know. I would assume you can and then put a new rivet in. But that's an assumption.
Hopefully a member with an 05 or experience with one will chime in and help out! Sorry!
Old Oct 21, 2013 | 08:45 PM
CBredes's Avatar
okay, the pcv value is changed and I cleaned the MAS and MAP and still nothing
Old Oct 24, 2013 | 01:37 PM
CBredes's Avatar
Default Problem fixed
The car is fixed
I cleaned the EGR valve and now its starting and running perfectly. Thank you all for all your help and suggstions; we managed to fix it without spending much and only changing things that should be done anyways.
I hope this will help others in the future
gkathleenw
Feb 29, 2012 11:03 AM
Absolutpolack
Feb 23, 2012 02:07 PM
jpoogie84
31
Jan 8, 2012 06:29 PM
pcarey
Feb 20, 2011 09:12 AM
menaja19
14
Jan 2, 2008 09:21 PM
