Pulley swap questions
Ok I've done almost everything I had planned on to the car for this year which is everything in my sig. The only thing left is the smaller pulley. I'm going with a 3.5 as recommended from ZZP but I have a few questions.
1. What (if anything) will dropping to a 3.5 do to my MPG. 2. Will I need a smaller belt or will the stock one do fine. 3. When I order the pulley from ZZP I will also order the puller (Rent it that is). My question is do I need to also rent the ZZP backing plate? What is it for? I'm going with the modular set-up because who knows what the future will bring (Rockers / Cam). |
RE: Pulley swap questions
i was also thinking of doing the pulley swap, on my 05ss supercharged, do you recomend zzp, or have any comments or advice?
The only thing left is the smaller pulley. I'm going with a 3.5 as recommended from ZZP but I have a few questions. 1. What (if anything) will dropping to a 3.5 do to my MPG. 2. Will I need a smaller belt or will the stock one do fine. 3. When I order the pulley from ZZP I will also order the puller (Rent it that is). My question is do I need to also rent the ZZP backing plate? What is it for? I'm going with the modular set-up because who knows what the future will bring (Rockers / Cam). i was also thinking of doing the pulley swap, on my 05ss supercharged, do you recomend zzp, or have any comments or advice? |
