Programmable EMS?
Old Mar 10, 2010 | 12:40 PM
BUDDZZ's Avatar
Default Programmable EMS?
I'm just wondering if anybody knows where I can, or if it's possible to get a programmable EMS for a 03 Monte Carlo ss or a universal if they make them. Any help will be apriciated.
Old Mar 10, 2010 | 12:41 PM
EMS meaning...?
Old Mar 10, 2010 | 12:48 PM
BUDDZZ's Avatar
engine management system
Old Mar 10, 2010 | 01:00 PM
Wilco's Avatar
HP Tuner allows you to manage engine and trans in real time, it allows you to make changes to the engine/trans configurations, and you can also data log up to an hour through their MPVI Pro adapter.
Old Mar 10, 2010 | 01:07 PM
Does he mean a PCM? Because running a turbo I would hope he already had some kind of PCM tuning already done...
Old Mar 10, 2010 | 01:14 PM
BUDDZZ's Avatar
Yes he means PCM and I do already have tuning done I'm not simple bud. The HP Tuner does that take the place of the factory PCM? Or is it just a programer?
Old Mar 10, 2010 | 01:15 PM
HP Tuners plugs right into your OBDII port under your dash and using the laptop you monitor everything and make all the changes necessary, and then park the car and reflash the PCM.
Old Mar 10, 2010 | 01:22 PM
BUDDZZ's Avatar
Yeah thats pretty much what I'm looking for I guess. But the kind I'm looking for replaces the stock PCM and you put this on in its place. AEM makes them for 99-02 camaro's and I'm just looking for something similar. How many perameters does the HP tuner have?
Old Mar 10, 2010 | 01:24 PM
HP Tuners can change everything.
If you don't want to do your own tune, you can simply buy a "canned" tune from any of the 3800 vendors, zzp, intense, prj, overkill, etc.
Old Mar 10, 2010 | 01:29 PM
BUDDZZ's Avatar
K that would work. Do u know of anybody whos has used this before?
