Lorenzo |
12-20-2012 05:37 PM |
Pretty Proud of Myself :) but a few problems :P
Well this all started yesturday, ive been planning to fix my intake gaskets due to them leaking. The top once was leaking but i figured that since ill go that far i might aswell do the lower intake manifold. This was my first time doing it and i was doing it at the mechanic shop where i work at. I had some of my friends guiding me along while i was doing it. It took me 2 whole days, 8 hours at a time to do it but all i know is that its done right and i took my time to make sure everything was spick and span :D Replaced the lower gasket with felpros kit. They were metal :) Replaced the coolant elbows with Dormans new Metal elbows. I was going to go GM But couldnt pass up Metal elbows instead of plastic. Replaced the thermostat as well and did the valve cover gaskets. Everything looks sooo clean now :D Just some minor bugs to fix now. For somereason my trunk pop wont work, and when i place the car in Park or Drive the doors do not unlock and lock as they used too. Also When the car was idling there was no CEL but i felt as soon as i started to move in D That it felt like it was stuck in low gear. The cars revving up to 2000 and its barley moving. CEL Is on but ill take a look at it tomorrow! Any ideas on those problems? Thanks Guys! :)
