Powertrain swap from bottom?
Old Feb 17, 2020 | 10:57 AM
haha chad's Avatar
Default Powertrain swap from bottom?
Is it better to drop the cradle to swap the powertrain or pluck everything from the top? I have a rusty built monte i want to swap everything from it to the clean monte i just got.
Old Feb 17, 2020 | 12:12 PM
From the factory its installed from the bottom. So if you've got a way to lift off the body, that's an easier route.
With that said, these engine bays are big enough to come out the top if all you've got is a engine hoist - you just have to tilt it on removal to clear the brake / ABS stuff and have to remove the downpipe.
Old Feb 17, 2020 | 12:36 PM
haha chad's Avatar
I have pluck the motor from the top at lease a time or two to say the lease. I dont have a lift just a cherry picker. Have anyone done it both ways? Idk if lifting just the front with the picker would give me enough clearance
Old Feb 17, 2020 | 01:09 PM
haha chad's Avatar
Old Feb 17, 2020 | 03:31 PM
I've done it both ways, although coming out the bottom we used a 4 post lift to get the body off. It was definitely easier from the bottom as there was no angling anything or fighting clearance.
However being you've only got a cherry picker, I'd just pull it out the top - especially since you've done it that way before. I don't see a benefit to changing without a lift.
Old Feb 17, 2020 | 09:30 PM
haha chad's Avatar
I was afraid you would say that. Guess ill be pulling the axles and pulling the trans out the top also.
CBredes
Jun 1, 2015 08:24 AM
mairj40
Jan 23, 2012 02:25 PM
mike1991
Jul 10, 2010 02:53 PM
pitmen
Mar 22, 2010 10:47 PM
sebcar
Feb 10, 2009 04:41 PM
