Power steering
Old Jul 28, 2010 | 01:41 AM
Enzo354's Avatar
STILL SLOW
Default Power steering
I think this is the right section for this, but I cant figure out what my cars problem is. It runs fine but after the engine gets pretty warm the power steering stops working, it locks the wheel up. Lately Ive been running with defrost on to keep it cool so it wont happen. Also it gets loud, like a whining noise and my lights get a bit dimmer. Any Idea whats going on?
Old Jul 28, 2010 | 08:54 AM
Did you check your PS Fluid?
Old Jul 28, 2010 | 03:31 PM
MAMONTE's Avatar
IDK, sounds to me like your power steering pump is going bad. Also possibly that you are very low on PS fluid...
Old Jul 28, 2010 | 03:37 PM
Could the belt be slipping when it gets warm? I would think the sound is easy enough to recognize...
Old Jul 30, 2010 | 10:42 PM
monte07's Avatar
there should be a in line filter in the power steering lines it could be clauged take it to a shop to have it flushed out. it should help also every 10k miles it should be changed do to how fast the pump spins just as fast as the engine. so check that first.
Old Jul 31, 2010 | 03:26 AM
Enzo354's Avatar
STILL SLOW
The fluid was VERY low. If It doesnt help topping it off Ill keep checking all this other stuff. Thanks for all the great advice guys.
TomF106SS
Oct 6, 2014 10:13 AM
MJClemm
Oct 29, 2012 06:14 PM
01blackmonte
Oct 17, 2005 07:30 PM
tundra
Aug 15, 2005 05:24 PM
