plug wires...
Old May 19, 2006 | 12:02 AM
dickie34's Avatar
Default plug wires...
I've seen 8, 8.2 and 8.5mm wires on summit and what not. if im guessin right id say the 8.5 are the best ones to get. right? one thing im not sure of though is whats the best spark plug out there? gotta build her up one step at a time, just wanna do it right and put the best on that i can.
Old May 19, 2006 | 05:56 AM
z34phoenix's Avatar
Default RE: plug wires...
big question what engine?
for a supercharged i would go with a NGK iridium, or std copper. as platnum wont hold up under boost.
as for brand. i have heard too many complaints about the +2 +4 from bosch so i wouldnt suggest them
so far i have used AC delco rapid fire platnums and loved them and im dropping in the iridiums next.
Old May 19, 2006 | 09:05 AM
The Black Machine 29's Avatar
what about those e3 spark plugs i heard there the best
Old May 19, 2006 | 02:24 PM
DESS03's Avatar
hey stick with the ac delco branded plugs they tend to work the best in the 3.8's
Old May 20, 2006 | 11:43 AM
montejass's Avatar
There has been alot of discussion here and elsewhere on the subject of wires, plugs and coil pack upgrades. Alot of people feel that the aftermarket stuff is a waste of money and the factory equipment is just as good.
For those of you that have replaced these items with aftermarket stuff, did you see an improvement?
Old May 20, 2006 | 01:35 PM
DESS03's Avatar
well i have done it before on my 2000 monte i repolaced the coil packs and plug wires with msd stuff kinda netted me a little more power but you have to watch out getting the bigger wires becasue alot of times they arnt sheilded as well and casue radio inteferance[sm=gears.gif]
Old May 20, 2006 | 01:52 PM
montejass's Avatar
Were the gains worth the extra $$$ in your opinion?
Old May 20, 2006 | 05:03 PM
DESS03's Avatar
on a stock engine not really
Old May 29, 2006 | 09:58 PM
dickie34's Avatar
i have the 3400, bout to put headers, intake, larger tb, and get a programmer. when i get the wires and plugs i want to get an MSD ignition box as well.
Old May 31, 2006 | 10:24 AM
rchurch's Avatar
I am going with a programmer, CAI, ram air hood, high flow cat, u bend delete, flowmaster duals, and 1.8:1 SLP roller rockers. I am definately going with the new wires, but do you think I should also go with the Accel coil packs?
