Performance radiator?
Old Mar 25, 2010 | 08:47 PM
Enzo354's Avatar
STILL SLOW
Default Performance radiator?
My 2000 SS sprung a leak. If my radiator cant be fixed and I need a new one, are there any thinner ones so I dont have to worry about it bumping the headers, or mabye a higher performance radiator for this car. Im just looking for ideas.
Old Mar 25, 2010 | 09:01 PM
No need for a higher performance radiator, just get an OEM replacement. Also- what do you mean by 'bumping the headers'? Are you talking about during install- because the fans should still be between the radiator and headers during operation.
Old Mar 25, 2010 | 09:10 PM
Enzo354's Avatar
STILL SLOW
No the headers are actually almost touching the fan motor. I have heat wrap on it, and the wrap touches the fan motor when the engine moves around.
Old Mar 25, 2010 | 09:33 PM
monte07's Avatar
do you have shorter dog bones you may have to put back the original length dogbones do to the clearence issues.imo i dont think it is good for the engine if the headers are that close to the engine. because the radiator wont have a chance to cool the coolent and trans fluid as well as it should. it would be putting it in a heat bind if there is high heat that close to the radiator imo.
Old Mar 25, 2010 | 10:37 PM
Enzo354's Avatar
STILL SLOW
I have regular dogbones.
Old Mar 25, 2010 | 11:42 PM
The bad thing is, no radiator is going to be significantly more skinny than what you already have. A lot of people have headers in 6th gen montes- I haven't heard any issues. What headers are they? The only thing I could think of is to do poly mounts to keep it from directly touching. Do your fans have factory heat shields like some wbodys do?
Old Mar 26, 2010 | 07:32 AM
East's Avatar
I know the radiator on the police package impalas (3.8l) is beefed up but I really doubt it would fit in our engine compartment.
Old Mar 26, 2010 | 07:44 AM
You can find bigger, but I wouldn't look for smaller.
Stick with what you have.
Old Mar 28, 2010 | 05:35 PM
biggriggs's Avatar
Mine has a metal heat shield on the back of the fan motor. One of the header primaries (tog's) is pretty close to it yet I still have enough room there to rock the engine forward when i need to.
Is it possible that one of your lower motor mounts is bad, causing the engine to lean forward a bit too much somehow?
If the lower mounts are good, then I'd second the suggestion for poly mounts (or flipping your stock upper mounts if you haven't already).
-Riggs.
Old Mar 28, 2010 | 06:40 PM
Enzo354's Avatar
STILL SLOW
My stock mounts are flipped and the heat shields were removed to allow the headers to fit. And Im just putting back in a stock one. They are SSAC headers
