Painting My Engine Cover
Old Apr 10, 2012 | 07:17 PM
brendan127's Avatar
Default Painting My Engine Cover
So I will be painting my engine cover. Picking up the high heat paints, white, red, and black. I will also be getting high heat clear coat, and some more plasti dip for my center caps(the back 2 have silver specks cause I ran out of plasti dip), and possibly VHT red caliper paint too because I plan on painting my calipers. The cover will probably come out looking like Ashley's just cause I like it and the way the colors go with my monte. I am not ordering letter covers, I will be doing some expert masking that I learned the trait of when I plasti dipped my Blazer badge when I had it(ha). Scotch brite pads are in the list too I think? Lol. I already cleaned it with Fantastick OxyPower and paper towels.
Here is what i'll be working with(picked it up to day for $10 from a nearby junkyard, they had another one at least(i had to look for them in trunks of monte's myself) if anyone is interested).
Old Apr 10, 2012 | 07:38 PM
Good Luck with the project. Mine is getting a paint job too.
Old Apr 10, 2012 | 07:52 PM
brendan127's Avatar
Thanks man. Hope yours turns out good too.
Old Apr 10, 2012 | 08:19 PM
zzapultimate's Avatar
This seems to be a popular mod lately I wish there was a cover for my 3.1L.
Good luck!
Old Apr 10, 2012 | 08:23 PM
brendan127's Avatar
Good luck!
I need to go get a new anti-freeze container too, that thing is so nasty on the inside, and you can see all the grime from the outside of it too.
Old Apr 10, 2012 | 09:42 PM
Budsjlm's Avatar
Got a pic of your plan? Just finished mine just waiting to clear it,
And a quick tip might want to move your Amp power wire to your Bat
Old Apr 10, 2012 | 10:08 PM
brendan127's Avatar
Why? It's not powering anything.
Old Apr 10, 2012 | 11:06 PM
Budsjlm's Avatar
Well nevermind then, not used to some one having it ran with nothing in the trunk
Old Apr 11, 2012 | 08:50 AM
i wanna paint mine so badly! but im not the most artistic person lol id make a mess
Old Apr 12, 2012 | 02:02 AM
brendan127's Avatar
Yeah, I got the car like that. What's the advantage of it being hooked directly up to the battery though?
Update on the project
It looked promising at one point!
Then it all went to **#%%%!!
^that pic is after several hours of trying acetone and sanding to try to fix it. I've got it as smooth as I could get it and I'm going to buy another white can and try to fix this..
