Over heating
Old Nov 22, 2011 | 08:53 PM
Rick11's Avatar
Default Over heating
I have a 03 monte 3.8 l-36 I start the car it it runs fine after warm up it starts to knock as if there is no oil and when I went to check the oil level the dipstick was too hot to touch so I checked the temp guage and it reads normal why would this engine get hot like that after only running for 5 to 10 min is it possible that there is not enough anti freeze or air trapped in the cooling system.
Old Nov 23, 2011 | 08:45 AM
Pop your engine cover off, open your thermostat bleeder valve and start the car. Get it to the point that coolant is flowing out of it and you'll know it's not air
When was the last time you flushed the coolant?
Old Nov 23, 2011 | 10:28 AM
Blazed SS's Avatar
IT HERTZ
here is what it looks like
Old Nov 23, 2011 | 10:31 AM
Rick11's Avatar
When I pulled the engine cover discovered that the plastic fuel line had melted after I repair this I will do a coolant flush I have never done a coolant flush since 2003.
Old Nov 23, 2011 | 11:29 AM
Then there is a good chance that the Dexcool (which at a MINIMUM should be flushed every 5 years, I do it every 2) is very thick and nasty right now.
I would drain everything, and circulate water through your system, drain the water, and repeat with water a few times. Then fill back up with a 50/50
oneandonlydylawn
Jun 2, 2013 02:15 PM
chamberz
Jul 15, 2009 02:02 PM
connersdad19
May 29, 2009 03:24 AM
sprfrk2005
May 20, 2009 09:15 AM
bjar61
Jan 7, 2009 04:48 PM
