out of ideas please help!!
i have 1997 chevy monte carlo 3.1 ltr last year i redid the heads put everything back together started it it was fine started ticking then got louder.i changer the oil pump and pick up screen but still isnt getting oil the the rockers i took off valve covers abnd started it no oil shot out of any of them.the oil has been changed and filter,the oil light comes on only at idle if i rev it up it goes out till idle again then back on the motor only has 130,000 miles on it any suggestions thankyou!!!
cracked flex plate possibly? not sure just thinking out loud....
Originally Posted by ucantseeme702
(Post 511543)
When you removed the lifters....did you soak them in a oil bath? before you put them back in the motor?.....If not...then your going to have to tear it down again and bathe the lifters...this will fill them back up oil and remove all the air thats in each one of the lifters.....:thumbsup: |
thankyou david i will try that!
also i just wanted to tell you that it is knocking really bad is that because no oil to the bearings?and can i get the lifters out without taking off heads?
Clogged PCV?
(Post 525877)
Revving the motor with zero oil pressure is a definate huge no no...:eek: Just to be through.... IF it was mine .... I would tear it completely down and go thru each and every bearing/cap etc in the motor .... I know thats probably not something your gonna want to do/or hear ..But it might explain some of the knocking/ticking issues.... Did you change the oil filter?.... If so, I think it would be wise to crack it open (the old filter) and check for metal shaveings.... Thats a definate sign of a Bigger issue thats going on inside your Motor...:thumbsup: I could be wrong...But since you said theres no oil flow to the topend.. after replaceing the screen and oil pump.... Id be suspicious... Maybe someone else will chime in and have new/bettter idea on this issue your haveing...Hope it helps.:) |
