-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   Oil Pressure (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/oil-pressure-31791/)
RoyAAdams Oct 27, 2011 05:31 PM
Oil Pressure
I have a 2000 Monte SS with a 3.8 For the last couple months I've noticed when I started the car the oil pressure gage would not move. I would turn the car off, restart it and the oil pressure gage would move and be fine. It has now stopped moving at all and the oil pressure light and buzzer is on. The car has about 146K on it but runs great. I can't hear any knocking at all while the engine is running and the light is saying no oil pressure. Any idea's out there on what my problem might be??? Thanks in advance for any reply's..
Roy in Pa.:confused:
zipper Oct 27, 2011 06:30 PM
This may be a silly question but have you checked the oil?
cdmorgan1972 Oct 27, 2011 06:53 PM
where is the oil pressure senor on a 2007 monte carlo 3.5 motor
RoyAAdams Oct 28, 2011 12:42 AM
Checked the oil several times actually just to make sure and that's definitely not the problem.
zipper Oct 28, 2011 06:35 AM
I just wanted to know how the oil level was. 6th gen Montes usually have some electrical gremlins. If you search for something like gauges not working, you should be able to find something.
bumpin96monte Nov 5, 2011 12:16 PM
If both the light is on and the gauge is dead, I bet your sender died. For the 3800- the sender comes off the adapter that the oil filter screws onto. Its real easy to switch out- just unplug and unscrew.
I'm sure the car has oil pressure though- you wouldn't be driving it around that long with 0 oil pressure.
rkarrjr Nov 17, 2011 11:42 AM
Anyone have the problem of Low Engine Oil light being on at start up? I have changed out the sensor on the bottom of the oil pan,with no luck.Thanks for the reply.
