oil cooler lines leaking at radiator
Old Nov 10, 2013 | 07:08 AM
Krazys02's Avatar
Default oil cooler lines leaking at radiator
I have a new radiator with the quick connect lines. Once i installed the new radiator i noticed the oil cooler lines were leaking at the radiator fittings. I figured since the top line had a nice scrath on the flare and both lines had rust i would replace them with factory lines and kill two birds with one stone. After replaceing the lines they leaked even more at theradiator. I'm going to try the old radiator fittings and see if that fixes the issue. Any ideas? 3.4l 2004 monte carlo
Old Nov 10, 2013 | 11:22 AM
MonteSS_Rider's Avatar
i had something similar happen when i upgraded my radiator... picked up the wrong year radiator and had to go back for the correct fittings.
cheap fix, even cheaper at a pick-a-part. good luck.
cxt35
Jan 6, 2013 10:14 PM
blackbeauty89
Feb 11, 2012 11:15 PM
montecarlocrazy
Sep 18, 2010 08:17 PM
ljm105
Feb 14, 2008 07:00 AM
