No spark...
replaced my 3.4 engine in my 03 (out of a 03 impala with only 65k on the engine). with that we also replaced, spark plugs, wires, air filter, ignition module, battery, heater a/c control unit. made sure all wire harnesses lined up and had good prongs, and were making contact. triple checked ground wires. its getting fuel, you can smell it and hear the pump. but we have no spark
. i currently have a new ECM on order but my mechanic is arguing that it started the car before we swapped the engine so why wouldn't it now? he insists there's a wire problem. but i was also told last year my ECM was bad by him and the dealership. my security light is not flashing so its not passlock (but that doesn't effect spark anyhow, that disables fuel to the engine) if it was the crank sensors (i have 2 of them) i would think that the ECM would be reading they are bad..but it doesnt bring up any codes.
Is there ANY thing else that maybe we are overlooking that someone else out there has had this same issue or something close that could give us something else to check into? ANYTHING would be of help please
. i currently have a new ECM on order but my mechanic is arguing that it started the car before we swapped the engine so why wouldn't it now? he insists there's a wire problem. but i was also told last year my ECM was bad by him and the dealership. my security light is not flashing so its not passlock (but that doesn't effect spark anyhow, that disables fuel to the engine) if it was the crank sensors (i have 2 of them) i would think that the ECM would be reading they are bad..but it doesnt bring up any codes.Is there ANY thing else that maybe we are overlooking that someone else out there has had this same issue or something close that could give us something else to check into? ANYTHING would be of help please
well since we still have my old engine we can take the crank sensors off of it and swap them (had spark before the engine swap). i find it odd that an engine with only 65k would have bad crank sensors but hey...ive known gaskets to go at 40k so its worth a shot to give it a try. i guess anything could have happened to the sensor after the car was in its collision, sent to a junk yard, ripped to pieces and moved around lol
Autozone will test your Ignition control module for free.
Is the engine turning (starter working?)
The second and thrid page of this guide shows how to test starter, coils and other various things on our engines specifically...
Part 1 -GM 3.1L, 3.4L Index of Articles
You mav have to do a crankcase re-learn procedure with an odb2 tool to try and get the engine insync with the PCM maybe...
Your stock pcm or the impala'a?
So, do you have a new Ignition control module? (Its the plate that your coils sit on) Also there are 3 plugs for the ICM, make sure they are all plugged in completely.
How did you test for spark? At the end of the wires or at the coils?
The link i posted shows how to test for spark.
Also... I just rebuilt my 3.4 and had to disconnect all the fuel lines under the hood. When i went to start it for the first time it would just turn and turn. It took like 45-60 seconds total of cranking to clear the air out of the fuel lines...
Maybe that is the issue and not a spark problem?
If the car requires a security re-learn everything works as normal, except the fuel injectors do not fire. So the fuel pump activates, coils send spark, starter cranks, but not a drop of fuel gets sprayed by the injectors.
Smelling fuel can be a bit of a false/positive. As I understand, you really should not smell fuel on a fuel injected car unless there is a leak somewhere. It's a pretty closed system. Now if you're looking for it, keep in mind various parts exposed to fuel are impregnated with the odor. You could be smelling it off those parts.
Plus, if you are spraying fuel but have no spark, you need to be concerned about flooding the cylinders. Has anyone pulled any plugs out? If you have no spark, they should be soaking with fuel after trying to start the car. A good way to check for spark is using a test light that plugs in between a plug and wire (or coil and wire), that will light up when it gets spark. Harbor Freight sells them for like $5-$10.
90º Inline Ignition Spark Checker
i want to thank you very much for the site with the trouble shooting. i had my hubby look it over and i read it 2x so i understood it well, and when we hooked the meter up to the crank sensor wire harness and when we would connect the ground it would shut the unit down so we tore the crank sensor out and was going to put the one from my old engine in and he couldnt get the harness to come up. here when he put the exhaust manifold back on it pinched the wires and damaged them
. so he took the harness from my old engine and hooked it up and she fired right up!! it was soooooo great to hear her run again!!
. so he took the harness from my old engine and hooked it up and she fired right up!! it was soooooo great to hear her run again!!Thread
Aug 27, 2012 08:24 AM
2000_BLACK_SS
16
Sep 26, 2006 04:36 PM
