Opinion Needed: Moroso Blue Max vs 8.8mm MSD
Old Nov 26, 2015 | 10:14 PM
rmorman's Avatar
Default Moroso Blue Max vs 8.8mm MSD
Hello all!
Getting ready to do a few improvements to the 383 over the winter. I did a baseline set of Dyno pulls so I can compare next Spring. While at the Dyno, the owner and his father both mentioned that they would swap out my 8.8mm MSD wires for Moroso Blue Max wires. Has anybody done a comparison? I've had the MSD wires for 10-15 years and had no troubles that I'm aware of. However, I'd make the swap if it would be worth it.
Thanks,
Russ
