LS4 swap in a 00 monte carlo ss
Old May 25, 2010 | 03:52 PM
TheMonteMan's Avatar
the bottom ends can really hold up that long? i dont mean like the rods,pistons,and crank. i mean more along the lines of the rings and bearings? id be worried about boosting a car with 120000 miles on it without at least a ring job. i have no experience with 3800s so i dont know just curious.
Old May 25, 2010 | 09:01 PM
Yes, they're really that strong. Plus, when we're talking boost- we're not talking a 20+ psi turbo setup; we're talking adding 40 horsepower with maybe 6 or 7 psi- so ring sealing isn't an issue. Not to mention, many 3800's (SC and NA) have lasted easily to the 200k mark- I still wouldn't worry about modding a 125k mile 3800 unless it has had the absolute snot run out of it.
Old May 25, 2010 | 10:55 PM
always good to learn something new.
Old May 25, 2010 | 11:50 PM
scottwern184's Avatar
wow ill keep that in mind then, but im lookin acheive 300+ hp/tq, so far all i got is the 180stat so you sure my bottom is safe for that?
Old May 26, 2010 | 06:16 AM
People have done nearly 400 whp on an L36 bottom end. Are you talking 300 whp or bhp? makes a big difference.
Old May 26, 2010 | 08:21 AM
300 HP at the crank will be very easy on a top-swapped engine with a few mods and a custom tune, and still reliable.
Old May 26, 2010 | 08:10 PM
300whp
Old May 26, 2010 | 09:03 PM
Bottom end will be fine for sure- but I'd bet you're going to be looking at either a cam or an IC to hit that kind of power.
Old May 26, 2010 | 10:54 PM
well im starting off basic, already got the 180stat, gonna buy the k&n intake next, then exhaust, and pcm. then im gonna start lookin to sc. workin on a tight budget here =P
but if im gonna be swappin out for an l67, im gonna do all the internal upgrades i can think of or ask you guys to think of before i get it swapped. gonna do headers around then too.
Old May 27, 2010 | 06:13 AM
That's easy- only real upgrade to do while you're down to the bottom end is to stick a cam in it.
