-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   leaking pvc valve? (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/leaking-pvc-valve-32689/)
blueSS Dec 12, 2011 05:48 PM
leaking pvc valve?
I noticed that it looks like the pcv valve is leaking (it sprayed on my UIM and engine shield)... It smells like gas... I took the valve out and shook it and i heard the valve move. What is the deal with this? If you noticed I made a thread a few days ago about having horrid gas millage. Anyone have a suggestion? 2001 monte 3.8 n/a
Yea i know i put pvc in the title instead of pcv...
The_Maniac Dec 12, 2011 06:55 PM
1 Attachment(s)
I have heard of the PCV valve making noise that results in a failed/missing O-Ring.
https://montecarloforum.com/forum/at...1&d=1323737483
monte carlo 3831 Dec 12, 2011 08:38 PM
aren't they cheap enough to just replace it?
blueSS Dec 12, 2011 09:18 PM
Indeed they are.. but i thought if i could hear it move back and forth when i shake it it was still good. Which the one I pulled out did. I was wondering if there was something more serious wrong with something... But I just replaced it so ill see if that works.
thesnowman20 Dec 13, 2011 09:06 AM
shaking it and hearing it rattle doesnt neccesarily mean its good.. it is good that you replaced it, besides they should be replaced regularly
John Kolakoff Mar 29, 2012 08:23 AM
2004 chevrolet 3.8 supercharged pcv valve
I have the 2004 Dale Jr. Monte Carlo SS 3.8 supercharged engine. I bought a new PCV valve. My son took it apart and can't remember how it goes back in.
Just a blank plate and two bolts. Does the spring go into the SC first or the valve? I assume the hole points down into the SC. The PCV valve doesn't feed through.
lougreen03 Mar 29, 2012 08:58 AM
Look here it should help with reassembly. It's part #117 and is located right by the supercharger in the picture.
LINK C ENGINE ASM-3.8L V6 PART 2 (L67/3.8-1);. Fits: 98 Regency, 98 Touring Sedan, Electra, Park Avenue , Ultra | Nalley Buick GMC Brunswick
http://parts.nalleygmc.com/images/pa...10GM00-152.JPG
