l67
Old Aug 24, 2009 | 04:15 PM
shingding88's Avatar
Default l67
the plan is to do an L67 swap into my monte myself. i saw the sticky at the top of this forum. how similar is it to the 05 monte ls?
Old Aug 25, 2009 | 02:24 PM
Do you have a 3800 now? If so, you could do a top swap.
There are two main differences I can think of:
A) the wiring harness, all you should need is a 3800 monte harness from your year (not sure what other years are compatible)
B) the axles- if you already have a 4t65e, then you won't need a drivers side axle
Old Aug 25, 2009 | 03:02 PM
the LS has the 3.4
the LT has the 3.8
RocknSS04
Dec 1, 2007 07:18 PM
RocknSS04
Sep 8, 2007 04:16 PM
chgs15
Feb 2, 2007 05:02 AM
04 Intimidator
Oct 30, 2006 12:11 PM
roadshoptuner
Aug 2, 2006 12:53 AM
