Knock Sensor and Crankshaft sensor
Old 11-04-2011, 06:46 PM
Crankshaft pulley is pressed on so you need a puller. They can be rented from autozone or bought for fairly cheap
Old 11-04-2011, 09:50 PM
nitehawkjcb's Avatar
Yep, you need a crank pulley puller, look on ebay for 3800 crank pulley puller or something like that, I got one for ~$30
Old 11-05-2011, 09:33 AM
philly94ss's Avatar
I have a pulley removal kit, now when I turn the pulley the whole crank turn. Any suggestions?
Old 11-05-2011, 10:32 AM
philly94ss's Avatar
What bolt size do I need for the pulley? The kit I rented from advance auto don't have the right bolt size
Old 11-05-2011, 12:22 PM
I believe it's a 15 mm, but I also think you need a 3x00 specific puller
Old 11-05-2011, 12:50 PM
philly94ss's Avatar
So out of frustration I put the car back together, fired it up and wa-la! No CEL. I changed the knock sensor yesterday, after getting the knock sensor bank 1 code followed by the crank an camshaft sensors. Could the knock sensor have thrown the codes for the crank and camshaft also? I drove about 1/2 mile and still no CEL or no service engine soon indicator.
Old 11-05-2011, 01:01 PM
Keep in mind you need to do a full drive cycle to know whether the CEL will come back on or not. That usually equates to anywhere from 15-30 minutes of driving. The car needs to be driven long enough to go to closed loop mode before you'll know for sure.
Old 11-05-2011, 05:35 PM
philly94ss's Avatar
thanks.
After making a 15Mile drive which took about 20 minutes, I didnt get any CEL. I will post in the morning if i got one tonight after a 30-40 mile ride.
Thanks for helping me out. Thank car gods for the "World of Forums"
Old 11-05-2011, 10:41 PM
I dunno man, if you disconnected the battery then your CEL isn't on because it hasn't failed
When my crank sensor went out I didn't even throw a code for it
Old 11-06-2011, 10:47 AM
I like how easy it makes it look to get that rear knock sensor out- I bet that thing is a nightmare between the exhaust, rear cradle, PS rack, and transmission in the way, lol.
Quick Reply: Knock Sensor and Crankshaft sensor
