K&N Air Filter
It's probably one of the simplest mods you will ever do. Depending on your skill anywhere from 30 from setup to cleanup to 1 hour if you have to take it slow to 2.5 hours if you are a complete putz.
ORIGINAL: Yellow SS
how is the change in performance?
The big bonus is you don't need to buy another air filter again so it is worth the cost right there.
Flipping the engine mounts .... I was able to feel that a LOT more than I did the drop in K&Nstock replacement. Granted nothing other than the filter itself is removed or replaced for a drop in, but they're good for a bit of power.
here you go i hope this helps it all there ........
http://www.knfilters.com/instructions/57-3045_inst.pdf
Hi All
Just installed a K & N FIPK (#57-3045) this morning, took all of an hour, regular hand tools needed
only "odd" thing needed is a #25 torx bit for the ECM cover screws. Nice increase in power and throttle response, and the best part, now you can hear the supercharger whine better!
Aaron
Aaron
