Intake install problems
Old May 7, 2009 | 10:43 AM
2000_BLACK_SS's Avatar
This is whaat mine ended up looking like after doing 3 different intake setups. i personaly think it is worth it because i like my intake set up alot more then just the K&N one (no offense if you have one) but it makes it my own not jsut something i bought
Old May 7, 2009 | 10:46 AM
Originally Posted by Bossnian
This honestly seems like ALOT of work. Is it even worth the time, money, or stress??
yes, yes, and yes.
You are talking about MPG gains + HP gains + your engine will keep cooler easier + you will inhale better (so you'll have to get it to exhale better too)
it's a very good mod. So either fix what you have, or save up and get a kit. These engines can mod easily, but it does add up if you don't want to spend the time and stress doing it custom.
Welcome to the frustration of modding
Old May 7, 2009 | 10:47 AM
The Popcorn King's Avatar
Now that i see everyone doing some form of CAI, i might just see about making one for mine.
Old May 7, 2009 | 10:51 AM
save it for the 6th gen, make your son do it :P
Old May 7, 2009 | 01:53 PM
biggriggs's Avatar
You don't really need a PCM tray.
The idea is to keep the PCM tray from moving around the engine bay when you're driving.
What i did was took a bungee cord (a red one even, to match the theme of my car's paint job) and strapped the PCM down to the radiator support brace that is under the airbox. Was like a 50 cent solution.
That sucker isn't going anywhere now.
-Riggs.
Old May 8, 2009 | 10:52 AM
Bossnian's Avatar
Hmmm...well I think I'm going to figure this out then. I think I'll use bungee plus zip ties. The only problem is that the air filter I bought has a hole is too small for my hose. Can anyone think of a hose/pipe that can go from 3inches to 4inches?
Old May 8, 2009 | 10:59 AM
if your filter is a 3" hole going to a 4" hole it's not going to be a good free flowing filter for your set-up. This is why we are against those fake cheap-o intakes. lol
trying to cut corners to save money, still leaves you with cut corners.
My best advice might be to try to return some stuff, and get the proper size filters and things, but if you want to make those work, I'm sure you can go to any autoparts / home improvement place and get a 3->4 pipe / attachment.
Old May 8, 2009 | 04:43 PM
biggriggs's Avatar
You can buy reducing couplers online that will go from 3" to 4". They should have them at autozone (or similar stores)too, as I think Spectre makes some.
You may need a short piece of metal tubing to clamp everything together depending on what tubing you are using.
If I were you though, I would try to return the filter if at all possible and get one with a 4" opening.
-Riggs.
Old May 17, 2009 | 01:08 AM
Bossnian's Avatar
eh, I already bought a 4'' intake and a 4'' pipe but the pipe was almost impossible to put on but it fit.
seanpeezy
Jan 10, 2016 04:05 PM
Knightwolf702
Feb 7, 2014 09:53 AM
Killacam
FWD Tech Guides '95-'07
25
Sep 6, 2012 11:28 AM
augi
Mar 25, 2012 12:17 PM
kissmyss03
Jul 7, 2005 12:18 AM
