5th Gen ('95-'99): Ignition Coil / Engine Bay Wiring Questions
Old Mar 10, 2015 | 09:24 PM
dreamka's Avatar
Default Ignition Coil / Engine Bay Wiring Questions
I have a harness from a 1998 Monte Carlo 3.1 and I'm swapping it into a cavalier and can't figure out a couple of the plugs.
I have an open plug on the top of the ignition coil the 3 pin connector on the drivers side is open. Where does that harness come from or go to? Is it a simple 2 wire harness from the crank sensor to the coil? Fairly confused on this one.
I also have a 3 pin triangular female connector with yellow weatherseal around the front of the transmission. I believe this may be the a/c pressure switch connector. Can someone please confirm that for me as well?
Old Mar 11, 2015 | 06:37 AM
l67ss's Avatar
Pics?
Old Mar 11, 2015 | 10:02 PM
dreamka's Avatar
I'll try to snag a picture in the morning and post it up.
f16fixr
Oct 9, 2014 12:55 PM
killerBee
Apr 15, 2013 11:57 AM
Cowboy6622
Mar 21, 2011 08:00 PM
SpinEm_90
Apr 2, 2010 11:44 AM
Mike95MonteLS
Sep 25, 2006 01:36 PM
