I need a bow tie motor head for some answers
Old Dec 3, 2011 | 11:11 AM
jluta2007's Avatar
Exclamation I need a bow tie motor head for some answers
I drove my 2002 SS home from work, it ran fine. Two hours later I tried to go some where and it started but ran REAL rough. It died when put into a gear, then finally would refuse to start at all. I pulled a plug an the spark is a yellowish orange color. Also my car started to randomly cut out about 6 months ago. I had plugs put in it but that made no difference. Any help would be awesome as I need to fix it as finacially as possiable. Thanks, Tim
Old Dec 3, 2011 | 11:21 AM
mrl390's Avatar
Have the fuel pressure checked with the key on engine off and then with the engine running. You may have a plugged fuel filter or a bad fuel pump.
Old Dec 3, 2011 | 12:07 PM
jluta2007's Avatar
Got a new fuel filter, but now that you mentioned it I ran out of fuel 3 days ago. I can hear the pump prime the motor when the key is turned to on.
RickCoMatic
Apr 5, 2008 09:23 AM
Twisted_Metal
Mar 30, 2008 01:49 PM
big_mecho13
Feb 27, 2008 05:44 PM
RickCoMatic
Jan 16, 2008 06:49 PM
big_mecho13
Jun 17, 2007 08:24 PM
