HPTuners vs. ZZP 1.0 PCM
Old Jan 16, 2012 | 10:59 AM
Bait's Avatar
Question HPTuners vs. ZZP 1.0 PCM
Hello,
I would like to know what the difference is between the two. They seem to accomplish the same in the end. The differences are cost and ZZP 1.0 PCM is a one time whereas HP Tuner VCM Suite can be used over and over.
Thank you for your time.
Old Jan 16, 2012 | 11:04 AM
Buying a ZZP tune, they just load safe values to a computer and mail it to you.
HPTuners, you sit inside your car and use your cars information and data to make more personalized changes.
Old Jan 16, 2012 | 11:10 AM
I use HP mainly for my GTO but i did tune my Monte with it, in the end i believe HP is the way to go especially if your gonna do more to your motor after the tune
Bait's Avatar
With ZZP would I be able to buy one from a yard first and send in or should it be mine?
What is expected gain on a Stock motor?
I know with bolt on's it will up accordingly so I am asking for stock or near stock as a baseline.
Old Jan 20, 2012 | 07:39 PM
Bait's Avatar
I see with ZZP that you can download .bin .hpt. What hardware is needed and/or any software needed to install?
Old Jan 23, 2012 | 08:55 AM
You would need tuning software to flash to your PCM.
Either DHP (for the .bin) and HPTuners (for the .hpt)
Old Jan 23, 2012 | 09:22 PM
Zen's Avatar
Zen
We use HPTuners on Jess's cavi.An we tuned it on the dyno.It's better than a mail order tune even if you don't use a dyno an do a street tune
zipper
Jun 1, 2015 07:50 AM
forgotten
Mar 30, 2012 09:19 AM
The_Maniac
Nov 10, 2010 09:42 AM
rrobert05
Aug 1, 2006 03:11 PM
