grounding
Old Mar 20, 2006 | 03:37 PM
crazycarl's Avatar
Default grounding
I am starting to redo all the ground wires on my engine (DOHC 3.4), I was wondering if anyone else has done this already? If so, where was the wire placement that you saw the best results from? I've added one from the passengerside strut mount to the lift mount next to the powersteering pump and have seen great results from just that, the power band feels much more solid in the midrange. If no one has done this to this engine yet, I will make sure to keep everyone updated on how things are going for me because it's a really cheap upgrade (all you need is som 10-6 gauge wiring and ring terminals) that makes real power, and I can already tell, this engine is seriously undergrounded.
Econman
Aug 9, 2015 08:55 AM
LARZ313
Oct 10, 2008 07:56 PM
