GM - 2007-ENGINES : )
Old Jan 15, 2007 | 08:36 AM
Default GM - 2007-ENGINES : )
[align=center]Pictures & Spec's on GM Engines[/align][align=center][IMG]local://upfiles/714/7C655DBEF54C454591D75CCAA590A228.jpg[/IMG] [/align][align=center][:-]Click below[/color]link[/font] -EnJoy [:-][/align][align=center][:-][/align][align=center]http://www.gminsidenews.com/index.php?page=Engine_Guide[/align][align=center][/align][align=center]Example below[/align][align=center][:-][/align][align=center] 3.9 L LZ9 Engine[/size][/align][align=center][/align][align=center][align=center][font=verdana][/align][align=center][size=4]3900 3.9L V6 (LZ9/LGD[font=verdana nd="3"]Di*
[font=verdana nd="3"]Displacement: 3880cc
Assembly Site: Tonawanda, New York
Configuration: Overhead Valves (2 valves per cylinder).
Horsepower/Application:
227 @ 6000 rpm (G6 Convertible)
240 @ 6000 rpm (G6, Malibu SS, SV6, Uplander, Relay, Terraza)
242 @ 6000 rpm (Impala, Monte Carlo)
Torque:
235 lb-ft @ 3000 (G6 Convertible)
240 lb-ft @ 4600 (G6, Malibu SS)
240 lb-ft @ 4800 (SV6, Uplander, Relay, Terraza)
242 lb-ft @ 4800 (Impala, Monte Carlo)
Features: Dual Variable Valve Timing
Roller Rocker Arms
E85 Ethanol Capable (LGD only)
[/align][align=center][/color][color=#0000ff]* 3.9L Engine Owners - Monte Carlo
[color=#0000ff]242 HP[color=#0000ff]
[IMG]local://upfiles/714/1819F36E71EE40D7A6EDC736F93A92EC.gif[/IMG] [/align][/align]
Old Jan 15, 2007 | 11:30 AM
97silverls's Avatar
Default RE: GM - 2007-ENGINES : )
Dual Variable Valve Timing = vtec for a monte carlo
Old Jan 15, 2007 | 03:01 PM
[align=center]3.8 L Supercharged in Pontiac GP is rated @ 260 HP[/align][align=center]Does anyone know where they got the 20 HP[/align][align=center]over the Monte Carlo SS SuperCharged ??[/align][align=center][/align][align=center]
[/align][align=center]Displacement: 3791cc
Assembly Site: Flint, Michigan
Horsepower: 260 hp @ 5200-5400 rpm
Torque: 280 lb-ft @ 3600 rpm
Applications: Pontiac Grand Prix
Features: Eaton Supercharger [/align][align=center][/align][align=center]Wiz Kidd `Josh, isn't your 3.8 S/C rated @ 240 HP ?[/align][align=center][IMG]local://upfiles/714/75A5C233B4654196AC950FB0C59D55F8.gif[/IMG] [/align]
Old Jan 15, 2007 | 03:20 PM
97silverls's Avatar
[align=center]3.8 L Supercharged in Pontiac GP is rated @ 260 HP[/align][align=center]Does anyone know where they got the 20 HP[/align][align=center]over the Monte Carlo SS SuperCharged ??[/align][align=center][/align][align=center]In the pontiac they use the series 3 of the l67where as the monte carlos were using the series 2 l67. hope that helps[/align]
Old Jan 16, 2007 | 03:25 PM
rchurch's Avatar
Can I replace my '02 3.8 with the newer engine?
Old Jan 16, 2007 | 03:44 PM
wiz kidd's Avatar
thats wierd that the gtp engine puts out more horse power than the monte carlo, because it seems that my car is quicker than all the gtp's in town....i wonder if it was just a typo from gm! :-p lol
as far as i know the engines are exactly the same...i think the monte weighs a little less than the grand prix though...
Old Jan 16, 2007 | 06:53 PM
[align=center]
ORIGINAL: 97silverls
3.8 L Supercharged in Pontiac GP is rated @ 260 HP[/align][align=center]Does anyone know where they got the 20 HP[/align][align=center]over the Monte Carlo SS SuperCharged ??[/align][align=center][/align][align=center]In the pontiac they use the series 3 of the l67where as the monte carlos[/align][align=center]were using the series 2- l67. hope that helps[/align][align=center]
[/align][align=center]Hi Andrew -97silverls-, thanks 4 the post.[/align][align=center]What is the difference between the 3-167 & the[/align][align=center]2-167 ?[/align][align=center]Does any member know ?[/align]
2007 PONTIAC GRAND PRIX GT
Technical Specs
I checked the web & found the below infor:
[align=center]OHV Supercharged 3.8-Liter Series III, V6, 12-Valve, OHV, SEFI Engine; Front Mounted With Horsepower Of 260@5400, Torque Of 280@3600, Cast Iron Block and Cast Iron Cylinder Heads[/align][align=center][:-]Click below site for more [:-][/align][align=center]http://www.autosite.com/content/rese...andardFeatures[/align]
Old Jan 17, 2007 | 06:51 AM
97silverls's Avatar
i believe its just an upgrade in the supercharger as the series 1 supercharger had i believe 220 the series 2 was 240 and series 3 260
Old Jan 17, 2007 | 10:56 AM
[sm=feedback.gif]
Is it the supecharger series that makes the difference in H.P.? or internal ?
or computer ?
Please share your knowledge.
*Thank 97silverls
for your post &
infor..
Old Jan 17, 2007 | 03:46 PM
97silverls's Avatar
HOPE THIS HELPS
Supercharged
The Series I supercharged engine went through many internal changes and the horsepower changed rapidly between the time it was introduced and the time that the Series II L67 was introduced. The supercharger was manufactured by Eaton, exclusvely for the GM 3800 engine. HP was rated at 205 for 1992-1993 engines, and 225 for 1994-1995 engines. The additional horsepower was gained by using a larger throttle body, and epoxy coated supercharger rotors, improving efficiency. The 1994-1995 utilized a 2.85" pulley versus the 2.55" pulley used on the 92-93 supercharger.
Applications:
[ul][*]Buick Park Avenue Ultra (Opt)[*]Buick Riviera(Opt)[*]Oldsmobile Eighty-Eight LS (opt), LSS (opt)[*]Oldsmobile Ninety-Eight (opt)[*]Pontiac Bonneville SLE (opt. SC package), SSE (opt) & SSEi [/ul]
Series II
Introduced in 1995, the Series II is quite a different engine. Although the stroke for the 3.8L engine remained at 3.4in (86mm), and the bore remained at 3.8in (97mm), the engine architecture was vastly changed. The piston connecting rods were 1in (25mm) shorter, so the crankshaft was redesigned. A new intake manifold improved breathing, and a new cylinder head had larger valves. The result was 205hp (153kW) and 230ft·lbf (312N·m), better fuel economy, and 26lb (12kg) lighter overall weight. In 1999 the 3800 Series II in the Chevrolet Camaro and Pontiac Firebird received a new throttle body with Electronic Throttle Control.
The 3800 Series II was on the Ward's 10 Best Engines list for 1995 through 1997.
L67 Supercharged
[/align]The L67 is the supercharged version of the Series II L36 and appeared in 1996, one year after the normally-aspirated version. It uses the Eaton Generation 3 M90 supercharger with a 3.8" pulley, a different throttle body, fuel injectors, cylinder heads, and lower intake manifold than the L36 uses. Both engines share the same engine blocks, but compression is reduced from 9.4:1 in the L36 to 8.5:1 for the L67. Power is up to 240hp (180kW) and 280ft·lbf (380N·m) of torque. Final drive ratios are reduced in most applications, for better fuel economy and more use of the engine's torque in the low range. The engine is built in Flint, Michigan. The engine was certified LEV in 2001.
This engine is or was used in the following cars:
[ul][*]1996-2005 Buick Park Avenue Ultra[*]1997.5-2003 Buick Regal GS[*]1996-1999 Buick Riviera (optional 1996-97, std. 1998-99)[*]2004-2005 Chevrolet Impala SS[*]2004-2005 Chevrolet Monte Carlo SS[*]1996-2004 Holden Commodore[*]1996-1999 Oldsmobile Eighty-Eight LSS (limited)[*]1996-2003 [l
