Flashing CEL and slow shifts
Old May 3, 2010 | 08:36 PM
Overdose666's Avatar
Default Flashing CEL and slow shifts
Alright today i was testing my new hood scoop to see if it would hold on at highway speeds and i noticed something odd. My CEL, ABS, and TRAC OFF are normally on, and when i turned on the car my CEL started to blink for a few seconds and my tach was jumping a tad erratically. When i was making a turn to get onto the highway my trans got stuck for a few seconds between 2nd and 3rd and my tach jumped to about 5. Once i was on the highway i noticed that it was shifting very slowly, even when i was flooring it. The past few days my car has been shifting pretty hard, i figured it was bc i was driving a little recklessly. Now with this problem I'm a bit worried for my monte, what could be causing this?
If u need anymore info let me know
Old May 3, 2010 | 09:52 PM
could potentially be the cat being clogged
Old May 3, 2010 | 10:05 PM
is that something i can fix or atleast check wihtout paying $$$?
Old May 3, 2010 | 11:34 PM
Sliver's Avatar
Get the codes read at autozone, if its safe to drive the car. A cat usually shows P0420 code.
Old May 4, 2010 | 09:02 AM
MAMONTE's Avatar
You have a misfire somewhere...could be a bad ignition coil.
What year and engine is your car?
Old May 4, 2010 | 09:34 AM
Your car is misfiring like crazy (flashing CEL) and it's throwing the car into a "safety zone" where it's pulling timing like mad.
Stop driving whenever you see a flashing cel and get that misfire fixed. Check all the plugs, wires, everything
Old May 4, 2010 | 03:04 PM
2003 3800 n/a
just got back from autozone got PO420 and PO480.....
bc of the laws here i need a new CAT but its gonna be cheaper to just hook up an emulator... ****
Old May 4, 2010 | 03:28 PM
ZZP Downpipe with Cat... still legal
Old May 4, 2010 | 03:43 PM
https://www.zzperformance.com/grand_...=551&catid=110
2.5" bolt + CAT?
P0480 Cooling Fan I Control Circuit Malfunction and wtf does this mean?
Old May 4, 2010 | 10:06 PM
nitehawkjcb's Avatar
This is just a guess, but perhaps it means one of the sensors on one of the fans is bad?
