Excited to see this! Need opinions
Old Mar 15, 2011 | 09:22 PM
my00monte's Avatar
Default Excited to see this! Need opinions
Hey guys!
I was just searching around for turbochargers and such and I stumbled across this on the ebay. Is a universal turbo kit for only $680 +shipping. I was just wondering what you guys think about it.
http://cgi.ebay.com/ebaymotors/UNIVE...item5ade1f4d7f
Thanks,
Tyler
Old Mar 15, 2011 | 10:00 PM
mrl390's Avatar
That is just a basic starter kit. It will not bolt on by any means without custom work. You will still need turbo headers or manifolds with a turbo crossover. It may have a large enough variety of bends/pieces to plumb everything on the intake side but you may still need to cut/bend/weld some new pieces to make it work. You also may need larger injectors and a higher flowing fuel pump as well as a good tune. Its also all generic ebay parts so I wouldnt expect it to be very good quality stuff. It basically has all the pieces you could source yourself, all the difficult pieces/work will still need to be done for it to work.
Old Mar 15, 2011 | 10:08 PM
my00monte's Avatar
So the ZZP Z3 Turbo Kit would still be a better choice?
Old Mar 15, 2011 | 10:31 PM
I think its a huge waste of money. The price may look cheap compared to the bargain turbo kits available- but it is missing 2 MAJOR components. #1 is the actual exhaust piping and mounting required to mount the turbo. The mount and exhaust routing for the turbo, wastegate, downpipe etc is the bulk of the kit- anyone can run some intercooler plumbing with universal pipe, but the hard part still needs to be done. #2 is the pcm tune- obviously you can't just mount that thing up and run it- you really should at least have L67 injectors, and you'll need a pcm tune too.
My other problem with the kit would be the questionable quality of the turbo. Look at the price of a T04E from AGP (a turbonetics turbo):
http://www.agpturbo.com/product.php?...cat=252&page=1
$1100 standard, or $1350 as a ball bearing unit
or a T04E from Garrett:
http://www.nipponpower.com/product.phtml?p=823
$690
or here is a Borg Warner 56mm like comes with the base ZZP kit (although this is extended tip):
http://www.agpturbo.com/product.php?...=0&page=1&js=n
that's $580.
Now I'm not saying you can't get a budget setup- but doesn't it make you think for a second when that whole kit costs just as much as the cheapest name brand turbo? Obviously the turbo in that kit is cheap junk (like one of those new $200 turbo's all over ebay)- and you can't honestly expect it to function well long term.
Doesn't your 2000 SS have a 3800? If so, why not get this:
http://www.zzperformance.com/grand_p...=964&catid=109
Some favorite quotes from the page:
Perfect for turbo projects!
lol, I'd hope so- its a turbo kit....
Our bearing turbo is easily capable of boosting 15-30+ PSI output at peak performance power.
Notice the lack of the word "ball" in front of bearing- I'd hope it has a bearing.... Also "30+ PSI" out of a cheap $200 ebay turbo, lol.
Minor modifications may be required.
Minor? Really? Like "minor assembly required" with a kit car right?
Turbo -
Properly Balanced
Isn't this assumed? If they didn't state it, should I assume its improperly balanced?
Turbo -
Made of High Quality Cast Material
Is it a mystery material? Also, cast isn't the big money thing- its billet turbos that are the expensive thing- not sure why they would advertise is being cast.
BOV pipe -
Made of High Grade Cast Quality
Is quality the material then? lol....
Oil catch can -
Preserves engine oil, Ensure Better oil efficiency.
Do they not know what a catch can is for? It keeps the engine oil out of the intake tract of the engine- not sure what that has to do with preserving the oil.
Oil line feed kit -
High Performance JDM Spec. Lightweight Design
Sweet- a JDM oil line...
Voltage stabilizer -
High performance
Well, that just says it all then....
This kit is almost bolt-on. You need a turbo manifold or have an exhaust shop custom modify your existing exhaust manifold to connect with the turbo and downpipe.
Piping kit needs to be modified slightly to the correct bends of your engine bay space/routing.
Downpipe needs to be fabricated at any exhaust shop or purchased online if available.
Sure doesn't sound like an 'almost bolt-on' to me!
Suggested but not required are fuel/engine management system used to tune for full effieciency and also safe daily operation.
So its not required to tune the pcm... seriously? So you can put this on, crank it up to 30 psi and it should be fine right? lol
Old Mar 15, 2011 | 10:37 PM
At least with ZZP you will get specific parts designed for your car not a "universal kit"
Old Mar 15, 2011 | 10:57 PM
my00monte's Avatar
Thanks so much for that HUGE write up! Great catches! Lol. I did look at it a little more and decided that if a whole turbo system costs ONLY $680, it couldn't be awesome. So all in all, this sale on eBay WAS too good to be true. I'll be saving for the ZZP Z3 Turbo kit. I can't wait to get this all set up and in place!
Thanks again, bumpin!
Old Mar 15, 2011 | 11:45 PM
my00monte's Avatar
Is there ANY way to grab a quality turbocharger for around $1000, maybe less? I don't understand why a FULL top swap costs like $1300 but has more parts, and requires more work to do, than a turbocharger, that costs $2300 (for a cheap one).
If it's possible to get a quality turbo for approximately the price of a top swap, I'll probably buy that instead of the supercharger setup, just because I can put it in myself and, in my opinion, it's more efficient than a supercharger.
The turbochargers I know of are the two ZZP Turbos, the Z3 kit, and the Z7 kit, and the Stattama kit.
If theres anyway to build my own, that might be an option too. Whatever works
Thanks a bunch!
Tyler
Old Mar 16, 2011 | 08:12 AM
You can always get your own built, but ZZP's cost includes the research and development costs that they ran. They make these for our cars, for a living. They run them, they love them.
Top-swaps are cheaper because it's all used parts and the quantity of W-Body cars on the road is so high and people are constantly parting them out.
There is also a crappy cartuning turbo for our cars.
http://www.3800performance.com/Merch...roduct_Count=0
Old Mar 16, 2011 | 08:36 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
Easy killer! I am more than happy with mine.
Old Mar 16, 2011 | 09:24 AM
Montess2k's Avatar
Honestly, other then looking for name brand parts (Like a borla exhaust, or SLP parts) on ebay, perhaps for cheaper then a store, EBAY should NEVER be used to buy any automotive parts...for some reason people mistake ebay for an auto store like ZZP or SLP and that is simply not the case...it is a flee market where a person/company will put anything in the discription to sell (ripoff) the unkown public.
It is good that you/others ask here and on other forums first so you do not get ripped off, but there is still a huge public that unkowningly purchases this stuff, and waistes there money.
Additionally, there are quite a few websites out there to do research, and if everyone is spending lotsa money 1500-3000 to get turbo/supercharger kits it should throw up a huge red flag that a 600 kit is probably not the best route to go in. Unless someone knows exactly what there doing and can do custom fab work, it is best to stay with a tried and true method that everyone else has done (ZZP,top swap, etc)
I know what everyone wants, especially youngin's who first get the car, they want to go fast right now for cheap, but paying less now, or for an item, ussually costs far more in the long run.
Trust me, if you want to go fast, be patient, save your money and get the correct parts and items, in the long run you will be happier, save money over all, and have a fast ride.
Joe
