Is this the Evap Vent Solenoid?
Old Oct 6, 2013 | 10:09 PM
JC Colon's Avatar
Default Is this the Evap Vent Solenoid?
Good Evening MCF.
I don't have pics, I'll get a couple during lunch tomorrow. In the meantime I'll discribe what I think is the Evap Vent Solenoid and it's location.
It sits on the back of the motor just under the strut tower and right, facing the car, of the alternator. It is rectangular in shape, has 2 Vacuum lines coming from the drivers side and an electrical connection on the passenger side. Although the connector and the Vacuum lines are in good condition, the part itself has been burned to the Point were there is burn damage on the fire wall insulation.
I have to assume that this part is cause some kind of problem But not knowing anything other than it has something to do with Vacuum prevents me from getting a replacement part.
When I got my EGR valve replaced I asked the mechanic what it was, he didn't know. One of the Vacuum lines goes into a splinter, then one hose goes into the EGR Valve, the other goes to the Throttle body.
Does anyone have an idea what this part is? I think I need it Bad!
Old Oct 7, 2013 | 09:45 AM
owens91's Avatar
That sounds like what I would call the evap purge solenoid...could be the same thing....I accidently got that replaced b4 haha
Old Oct 7, 2013 | 10:33 AM
KCFITZ78's Avatar
There is a "Vapor Canister"........... not sure of it's location but I think it is near the fire wall and is feed from the "Canister Vent Valve". The Vapor Canister contains and releases harmful fuel fumes from the fuel tank to the engine.
There is a "Canister Vent Valve with Solenoid" that is located next to the gas fill neck and purges excess pressure from the gas tank to the "Vapor Canister". If this fails the valve fails to "open" and you will get a code for a mass vacuum leak.
Old Oct 7, 2013 | 10:36 AM
KCFITZ78's Avatar
Also here is a "Canister Purge Valve".... maybe this mounts to the "Vapor Canister"????
Old Oct 7, 2013 | 10:59 AM
JC Colon's Avatar
I made a mistake. The Vacuum line goes to the fuel pressure regulator. I have a pic in my phone. I will post it when I get home. Can't post pics from the phone.
Old Oct 7, 2013 | 04:48 PM
z34phoenix's Avatar
if it goes to the FPR and attaches to the BBV, then it is the BBV solenoid. I found this pic on google. it is the yellow circle.
Old Oct 7, 2013 | 06:24 PM
JC Colon's Avatar
OK, this is the part I need
Here is a Bigger view so you can see the Vacuum Lines
From the "T" connector it Goes to the Front of the motor
You can see the second "T" connector
Here is the Full View.
As you can see, the vacuum comes from the TB. and if you look at the last pic, behind the part on the firewall there are Burn or Scorch marks. I took the last pick about 3 weeks after i got the car, April 2012, so it's been that way all this time. So I'm not worried about another fire. But I do want to replace this Whatever it is called. Of course knowing the name of the part would really HELP!
Thanks Guys
Old Oct 7, 2013 | 06:51 PM
z34phoenix's Avatar
Seriously those vac lines are all sorts of ........ Up! I see a 4way fitting and another t fitting upfront and a bunch of others... Is there a reason you have so many junctions? It can't be good for the system
And it looks like an evap solenoid.
Old Oct 7, 2013 | 07:13 PM
JC Colon's Avatar
Actually, there is a Very good reason. I bought the car that way. I've been working on cars for 33 years. I would like to fix it But there is No Vacuum line diagram that I can fined. And No n/a SS near me so I can't use another car to guide me!
Old Oct 7, 2013 | 07:43 PM
z34phoenix's Avatar
Ask and you shall receive....
actually #1 is acc and #2 is the brake booster.
