Engine Specs
Old Oct 8, 2008 | 02:49 PM
alkalinetri3o's Avatar
Default Engine Specs
I'm doing a rebuild on a 3800 V6 motor for a monte carlo and got the following out of round measurements for the rod journals on the crankshaft: 0.0004", 0.0003", 0.0005", 0.0003".
The tolerance according to GM is 0.0002" and I was wondering if the measurements I got are acceptable? I realize it is out of spec but how crucial is it that they are only less then 0.0003" over?
Can I reuse the crank or should I get it machined?
Thanks
Old Oct 9, 2008 | 07:15 AM
Badazgt's Avatar
Default RE: Engine Specs
did u use a reputable micrometer?
hey man will u come over on my thread about rebuilding a 3.8L and give me some pointers?
ive never messed with this v6 stuff before
Old Oct 9, 2008 | 04:18 PM
Yeah the mics are brand new and measurements for everything else are accurate
Also, I wouldn't mind helping you out either but this is also my first time messing with this motor so we'll learn together i guess
Old Oct 10, 2008 | 07:54 PM
04 Intimidator's Avatar
ORIGINAL: alkalinetri3o
Ouch. Ok, that was the wrong answer but you just don't realize it is.
Who is the manufacturer of the Micrometer and just because it is new is so the wrong answer I won't even get into it. The correct answer is - I have tested the micrometer on a set of gauge blocks of: .250, .375, .500, and .750.
As for the out of spec question, yes it is critical.
I would bring it to a machine shop, and more specifically a machine shop that specializes in race cars and performance vehicles. Otherwise bring it to a GM dealer and see who they recommend in the area.
Old Oct 10, 2008 | 07:55 PM
That might have been harsh and it wasn't meant that way. Long day at work.
Old Oct 11, 2008 | 12:37 AM
Badazgt's Avatar
yank the pistons and rods and take it too a good machine shop!! one that won't lie to make money
have him mic it and he can put the rods back in round EASILY if he has the right machine tools!!
good luck
again i would appriciate some responces to my posts guys!!
MIKE07083
Sep 30, 2007 11:14 PM
maximum98
Dec 27, 2006 12:21 AM
HaRvArDaLe
Dec 4, 2006 05:01 PM
CHOWEE21
Jul 27, 2006 06:49 PM
IaMsEpSiS
Jan 15, 2006 09:04 PM
