Engine Overheated!!! Thermostat?
Old Jul 5, 2019 | 03:13 PM
Originally Posted by Brandon Root
Some mechanics actually would use a smoke machine which send a vapor through the block to find leaks. (I took mechanic courses and have done this). Simple process and it shouldn’t take but maybe 5 minutes.
Honestly, I'm not sure anyone from this thread still exists on here as its 10 years old. The person you quoted hasn't been online here in more than 5 years.
Old Jul 9, 2019 | 09:19 PM
Justin Knight's Avatar
Smoke machine for a coolant leak is false. That would not work. Licensed for over 12 years and I can guarantee that wouldn’t be a valid method for coolant leak testing.
Best methods: Pressure test then look for leaks, ultra violet dye, boroscope and mirrors to find hard to find leaks. As for the 3.4 leak problem my guess is the factory block heater assuming the intake was done properly and not leaking again.
81mallyracer
Sep 14, 2015 08:13 PM
Sparky-88
Jun 11, 2011 10:53 PM
BlarneyStone13
Oct 30, 2010 01:48 PM
orthokneepa
Nov 2, 2006 06:55 PM
orthokneepa
Sep 5, 2006 10:30 AM
