engine monds for a 2006
Old Aug 28, 2011 | 10:23 PM
blackmonte781's Avatar
Default engine monds for a 2006
i have a 2006 monte carlo LT with the 3.5l v6. are there any mods for that motor? for ex cold air intake? would the motor be able to handle a turbo?
my monte has completly gone through a make over since i bought it stock and its all show and no go and i want to make the car live up to the monte carlo name . has anyone here done what im talking about doing?
also, how hard would it be to throw the SS motor and tranny into my monte? i know its easier to buy the real SS but this already has a full sound system wheels lambo doors custom painting interior and lights galore ha. thanks everyone
Old Aug 29, 2011 | 08:07 AM
You'll need the engine and PCM from the SS.
coldairinductions.com sells an intake for your car.
getoverkilled.ca can tune the car and wake it up a little.
Not many mods for the car though. You would be looking at totally custom for the turbo.
Old Aug 29, 2011 | 10:24 AM
oneslowmonte's Avatar
It would not be terribly difficult to swap an LS4 into your car, it's just plug and play. With exhaust a tune and cold air on that engine it will go a long way. While the engine is out I'd do headers, it'd be a lot more tedious to do that after it's installed. The trans is the same thing, you can take it to a shop if you cannot do the work yourself. And yes, you would also need the PCM as Chibi said.
Old Aug 29, 2011 | 07:27 PM
the trannys are the same? because my v6 doesnt drop to 4 cylinders? in cruise mode? and whats the PCM?
Old Aug 29, 2011 | 07:39 PM
Your transmission doesn't control the DOD. That's the engine shutting off the cylinders, not the transmission.
The 4t65e is used in both, the HD version in the SS, but you can turn your standard into the HD.
The PCM is the powertrain control module, on those cars there are 2, one for the engine and one for the transmission I believe.
Old Aug 30, 2011 | 12:50 AM
model16's Avatar
Yes there is two for the LS4 SS's, not sure about the V6s...
Old Aug 30, 2011 | 09:15 AM
would it be an expensive project to make the switch over to the 5.3?
Old Aug 30, 2011 | 09:30 AM
Yes. It would be a lot of down time too I would think.
Old Aug 30, 2011 | 09:44 AM
I've seen LS4's go for less than 1k with under 80K miles, so it's not terribly expensive, but you will definitely have to save up some money. There is also the fee for the shop to put it in if you cannot, the trans, shipping the engine, renting the pulley to drop it in if you don't already have one or know someone kind with one.
Old Aug 30, 2011 | 09:46 AM
i under stand the expense of the motor and all that. that i can deal with no problem. but my concern is is what exactly would i need. someone once told me b4 from chevy even said that id even need a whole new dash? like gauge cluster
