Engine Cleaning
Old Aug 21, 2012 | 08:32 PM
wtxbear's Avatar
Default Engine Cleaning
Have a quick question.... What ways do you guys clean up under the hood of your Monte. Most people i know go to a car wash and blow the heck out of it with high pressure water and degreaser, but is there a better way?
Old Aug 24, 2012 | 08:45 AM
MAMONTE's Avatar
I generally wait till the engine is completely cool, cover alternator and any exposed electrical connections with aluminum foil, spray it down with 100% concentrate Simple Green...let is soak for a bit, then wipe/ scrub heavy soiled areas, and then blast it with a garden house and super nozzle. Let things dry a bit, take the car for a drive to heat it up and help dry.
Old Aug 24, 2012 | 10:11 AM
Once the engine has been initially cleaned you can clean with a soapy rag alone (if you keep on top of it) I only use a soapy rag, occasionally use a garden hose maybe twice a year. However my car never sees winter
Old Apr 9, 2013 | 08:54 PM
sdowney's Avatar
Is there an effective cleaning method that doesn't involve spraying with a hose? I don't think I could consciously spray my engine with a hose. Just doesn't seem right.
Any ideas?
Old Apr 9, 2013 | 09:17 PM
zzapultimate's Avatar
Any ideas?
Simple green and a rag works really well.
Old Apr 9, 2013 | 11:52 PM
blackmonte02's Avatar
when I spray/clean my engine bay down some wiring must get wet and the car doesn't run well so I try to stay away from the engine bay
Old Apr 10, 2013 | 07:38 AM
Whatever you do it will take a couple hours easy to get the bay pretty clean. Pop a top and resign yourself to a Sat. morning of detailing your engine bay.
Found a link with some detailing information for you. Goog luck, it will be worth it when she is all squared away and sparkilng.
Engine Detailing, car engine cleaning, engine cleaner, engine detailing how to, how to clean an engine,
Old Apr 10, 2013 | 10:06 AM
owens91's Avatar
I think imma do mines this weekend off too
Old Apr 10, 2013 | 08:21 PM
sdowney's Avatar
Sounds good! Thanks all!
Old Apr 10, 2013 | 08:29 PM
Franks 03SS's Avatar
2011 Monte Of The Year
Simple green, a variety of brushes to get In between everything and a regular garden hose is what I use. I also put a bag over the alternator, coil pack and cover my Air filter, but I removed my filter today and just put a couple bags in the intake tube. I actually cleaned mine up today so I'll make a thread shortly oh and I also helped speed up the drying process with a leaf blower lol after it was all dry I finished it off with CD-2 Engine Detailer, stuff works Amazing!
