Engine bay dress up
Has anyone done anything to thier engine bay to make it unique? Besides painting the bolts, LOL
I want to make mine look nice,it's already clean, I just want to see your engine bay's, you know, get some ideas and stuff. |
RE: Engine bay dress up
After cleaning my engine bay up I quickly noticed the need for wire and hose coverings which I think would clean it up a bit.
I've thought about painting the engine cover.. but haven't decided on how i want it to look yet.
To me, just keeping it clean and detailed is [8D] Tj |
I forgot to add, an easy and neat engine bay trick is if you have the 3800 ( i don't know if the 3400 has them) the engine cooling fan covers come off, and with some neverdull you can make them shine like they almost look chrome.[8D]
Just pull out the plastic screws ( which suck) and remove the cover. Polish it up and replace them. The passenger side is the harder one to remove. You dont see them so easy from the top, but if you look from the side you can't miss them when they are shined up.:D Tj |
ORIGINAL: montejass After cleaning my engine bay up I quickly noticed the need for wire and hose coverings which I think would clean it up a bit. |
I wondered the same on the braided hoses... Are they covers or actually braided hoses? I am thinking of going with red wire covering.
I forgot to add, an easy and neat engine bay trick is if you have the 3800 ( i don't know if the 3400 has them) the engine cooling fan covers come off, and with some neverdull you can make them shine like they almost look chrome. Just pull out the plastic screws ( which suck) and remove the cover. Polish it up and replace them. The passenger side is the harder one to remove. You dont see them so easy from the top, but if you look from the side you can't miss them when they are shined up. |
Here's mine with the new WizAired CAI... I'm still in process...
http://memimage.cardomain.net/member...69_38_full.jpg http://memimage.cardomain.net/member...69_39_full.jpg |
ORIGINAL: montejass I wondered the same on the braided hoses... Are they covers or actually braided hoses? I am thinking of going with red wire covering. |
Rifrech.. what is the silver covering you used on the air intake hose?.
Tj |
ORIGINAL: 03SSdriver Rifrech.. what is the silver covering you used on the air intake hose?. Tj It's supposed to help keep the tube cooler from the heat off the exhaust that's right under it.. |
