Dropping to a 3.4" pulley
Old Jan 23, 2013 | 09:14 AM
04SuperchargeR's Avatar
Default Dropping to a 3.4" pulley
What mods would be required in order to drop down to a 3.4" pulley? all i have right now is a k&n cold air intake
Old Jan 23, 2013 | 09:21 AM
180 thermostat, headers or powerlog+downpipe, colder spark plugs, 1.9 modified rockers, a tune. Also a gauge to read Knock Retard so you know if you are safe on that 3.4 pulley.
Old Jan 23, 2013 | 11:05 AM
S.O.G.'s Avatar
1.9 rockers are needed to drop to 3.4? I am leaning more towards a cam. but I'd have to get new injectors huh? anyway I'd also add u-bend delete to chibi's list.
Old Jan 23, 2013 | 11:09 AM
Headers and/or Downpipe remove the u-bend.
If you want to cam, go for it
Old Jan 23, 2013 | 11:14 AM
S.O.G.'s Avatar
Yea I guess you're right I forgot about that haha with the exception off speed daddy headers :/
Old Jan 24, 2013 | 03:04 PM
I've been looking around for headers and I want to get ones that won't require a rediculous amount of labor hours, what headers should I get?
Old Jan 24, 2013 | 06:44 PM
nitehawkjcb's Avatar
04SuperchargeR, they're all gonna take about the same amount of time to install...
SS Supercharged LA, you don't need new injectors until you drop to about a 3.2/3.1 pulley IIRC.
Old Jan 25, 2013 | 08:08 AM
i have a 2004 Supercharged SS and i think that i already have a 180 thermostat but is that true? because im not positve
Old Jan 25, 2013 | 09:14 AM
Stock is a 195. If your car warms up and sits in the middle of the temperature gauge, you have a 195.
You swap the injectors when you are tuning and the flow-rate is above 90%. If you aren't tuning yourself... I wouldn't really go lower than a 3.4
Old Jan 25, 2013 | 09:42 AM
This means you don't have a scan tool. You NEED to pick one up, or you could very well blow that thing up changing pullies, if you don't scan after a pulley change and you have too much KR, you're gonna have a bad time.
