Dog bone engine mount bushings.
Old Oct 2, 2010 | 09:05 PM
7498MonteCarlo's Avatar
Photobucket
Monte Of The Month -- August 2010
Default Dog bone engine mount bushings.
Can you buy new rubber bushings for the upper 'dog bone' motor mounts? I think I need new ones lol.
Old Oct 3, 2010 | 01:44 AM
Enzo354's Avatar
STILL SLOW
What year is it? 03?
Old Oct 3, 2010 | 02:10 AM
probably going to be easiest for you to just get new brackets and everything off of a junk yard car or something, why do you think you need new ones?
Old Oct 3, 2010 | 08:30 AM
Photobucket
Originally Posted by enzo354
what year is it? 03?
1998.
Old Oct 3, 2010 | 08:32 AM
Photobucket
That would defeat the purpose of new ones, IMO.
The engine seems to jerk, WAY too much when I rev it(from under the hood). Also, 90% of the time, if I let up in the gas and coast, and hit the gas again, I can feel it jerking and makes a clunk. Feels like theres 'slack' in the mount bushings.
Old Oct 4, 2010 | 09:37 AM
zipper's Avatar
ZZP sells these that will work: http://www.zzperformance.com/grand_p...=130&catid=138
They will cause some vibrations though so keep that in mind.
Old Oct 4, 2010 | 10:51 AM
well if you get some newer ones it would help, but you could get the polys from zzp, the vibration isnt really that much more, i thought they would be and wanted them to be but they werent too bad.
Old Oct 4, 2010 | 03:51 PM
monte07's Avatar
i would check the others as well because of the vibration as well it sounds like they have all of the weight and trying to hold the engine. it is a percation
Old Oct 7, 2010 | 08:14 PM
Photobucket
Is there anywhere that sells just the standard, original, rubber ones? I really don't want to spend that much on those poly ones. =/
Old Oct 7, 2010 | 09:35 PM
dowmace's Avatar
Theres always the option to fill your stock ones, it's a good medium between poly and stock and will stiffen the mounts decently. Heres a link to a **shudder** mazda site that has a good how-to
http://www.mazda3club.com/showthread.php?p=413613
