Dash Controls going crazy!
I have a 2000 monte carlo ss with the message display center. First thing, my odometer display(digital) doesnt light up anymore. Then my gas gauge and oil level gauge are both off and fluctuating as i drive which causes the message center to inaccurately display "low oil pressure" and "low fuel". Now wen i drive it says my tire pressure is low but its not cuz i checked all of them. Do I need an individual sending unit for both the oil and gas gauge or is it just the whole electronic dash module itself? Could the actual tire sensor itself be bad or is it just a part of the actual dashboard itself going bad? Whats it cost to get this repaired? cuz i dont wana spend $500 like i did on my grand am..
Please help..thanx |
very common problem, the gauge cluster is going bad!
check here for info on getting it fixed....http://www.bbengineer.com/cars/impala/store.htm |
So is it the whole cluster itself or individual sending units? Cuz one mechanic told me to replace the oil sending unit and te fuel sending unit..
Originally Posted by Pretty00Pace
(Post 297932)
ok thanx
(Post 297899)
I thought that i would add wen i get a full tank of gas, the gauge reads correctly. Its not until ive used about a quarter of gas is wen it starts to read improperly. This is why i was unsure on whether its the sending unit or the cluster itself. But then my mileage reading doesnt show up anymore and i know this is part of the cluster. And my gauges do go back to zero wen the car is off so they arent stuck. So could it be both the cluster and oil and fuel sending units? im so confused..lol
| All times are GMT -5. The time now is 08:31 AM. |
