| BillyBob427 |
Oct 11, 2012 09:28 AM |
Coolant Issue. NEED HELP
I recently noticed that my coolant was brown and nasty, so I did a flush on the radiator. However, I didn't flush the whole system because I didnt get it warm enough to open the T-stat and flush coolant in motor. I did get the radiator good and cleaned out though. After "flushing" I reinstalled the lower coolant line and re-filled the radiator. Made sure everything was good, started it up for a bit, checked and re-added a little. The next day I drove to work and the low collant light came on. Got to work and noticed steam coming from near the overflow catch can area and behind the motor where I didn't touch anything. Went out to my car after work and checked the radiator. Couldn't even see coolant, so added. Got home and did research telling me to purge air out of the system, so I did that by opening the petcock up by the T-stat and adding while running until only coolant came out and no air bubbles. Thought maybe that was the issue. Drove to work the next day and low coolant light came on. Same steam from the firewall area passenger side. I can't figure out where it is leaking from. There is bubbling sound from firewall area (heater core???) now. Anyone have a suggestion to what is going on? There doesn't seem to be any coolant in oil, but it is leaking from somwhere. Did the new coolant magically create a leak or mess up an intake manifold gasket or something? Any ideas let me know. Thanks!
