-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   Check Engine Light On! (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/check-engine-light-14649/)
rgant_19 Jul 5, 2009 08:39 PM
I know its been 1 day but I noticed my check engine light came on while driving to the bank today. On my way of driving there, I stopped off at "AutoZone" (where they check any dashboard and electrical problems with your car for free) for the to check it. The guy told me it is because of my:
001. - Failed EGR valve
002. - Carbon blockage of the pintle
Now, everybody I do not know what the heck I am looking at and why. All I know is that I want it fix. If its a DIY job, then I will complete it. If not, then a pro an handle that one. The question is what could it be? If solutions will be greatly appreciated.
labnjab Jul 6, 2009 06:13 AM
I'm willing to bet money its your egr valve. Most newer gms have what they call a a digital EGR valve which contains the solenoid, valve and sensor all in one unit. 9 times out of 10 when you get any egr code for the valve (and you have 2 of them.), its a bad valve. Its a 5 min. job to replace it and anyone with a set of sockets can do it. I don't know what engine you have but on the 3.1, 3.4, and 3.8 its located on the drivers side of the engine and should look similar to this
http://arrc.epnet.com/autoapp/9317/c.../93174g08L.gif
Just undo the nuts (or bolts), electrical conncetion, clean up the gasket and intall the new one with a new gasket, clear the code and you should be good to go. I hope this helps
Space Jul 6, 2009 06:36 AM
:rolleyes:
Another great/helpful post with chart by
Member LabNjab
Great `infor, & if that's not the prob,
check out for a bad `cat : (
MCF = Member's Help'in Member's
4-Sure.
Thanks, LabNjab
rgant_19 Jul 6, 2009 12:57 PM
I really aprreciate it. I know it cost a lot to buy. Where exactly is it located? I have all the sockets in the world. LOL!
labnjab Jul 10, 2009 06:29 AM
Its should be located next to the throttle body
