-   Engine/Transmission/Performance Adders (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/)
-   -   Changing oil for storage? yay or nay? (https://montecarloforum.com/forum/engine-transmission-performance-adders-12/changing-oil-storage-yay-nay-18239/)
PINKFLOYD_ Jan 19, 2010 11:16 PM
If your oil has maybe 2,200 miles on it, with lucas and you start it every 2 weeks, is there really any point changing the oil before storage? I've read and heard that your suppose to change it before...But as long as you start it every two weeks it shouldn't matter as long as you let it run for about 30 mins, with heat on etc and stretch the legs often?
jeff Jan 20, 2010 07:08 AM
i would have oil is cheap it breaks down in time i wouldn t start it at all stablizer in gas tank un hook battrey an wait 4 summer everytime u start it ur scarin the pistions an roten ur mufflers after 2 weeks ur oil is all in ur oil pan that s what i do anyways ur choice
AwesomeSS Jan 20, 2010 07:38 AM
Yep - that's what I do - a clean full tank of gas (the good stuff), Stabil in the gas tank, and battery unhooked. Then I change the oil a little time after I get my car out of storage. My once a year oil change!
Cowboy6622 Jan 20, 2010 07:48 AM
I would change the oil AFTER leaving it in storage so if the oil is breaking down over time, you're not wasting your money. And make sure you do the full tank of gas with stabilizer. Otherwise, condensation can form in the empty space and cause your tnak to get rusty on the inside, clog up the fuel filter on the end of the pick up tube, and then your sitting on the side of hte road wondering why your car won't go anywhere.
MAMONTE Jan 20, 2010 08:33 AM
I would agree, change the oil AFTER you take it out of storage. And stop starting it every two weeks, all that is good for is keeping the battery charged, but you are doing more harm than good to your engine.
RickAKATed10 Jan 20, 2010 11:28 AM
Agreed.
K-Mac Attack Jan 20, 2010 11:33 AM
As cheap as an oil change is, I would do it before and after. Used oil has acids and such in them that can damage the seals. It just seems penny wise and dollar foolish to take the chance.
I agree that putting a full tank of gas with Stabil is a good idea as you don't want the tank to accumulate water or the fuel to become varnish.
biggriggs Jan 20, 2010 12:04 PM
I thought our gas tanks are plastic? /shrug
I'd just change the oil when you take it out of storage. Since it's all going to drain to the bottom of the pan shortly after you shut the car off, fresh oil isn't going to make a difference if it's sitting for a few months. I could be wrong, but I think starting it up for a few minutes every few weeks could cause moisture from the exhaust to collect in the mufflers and rust them out from the inside.
-Riggs.
Cowboy6622 Jan 20, 2010 02:07 PM
Are they? I've never really payed much attention to it. That would make a whole lot of sense for it to be a hardened plastic..... you're fuel can still have condensation which will make your car run weird though.... I'd still leave a full tank of gas in it.
bumpin96monte Jan 20, 2010 04:06 PM
x2, my monte has been in storage just over a year, and I left the old oil in it. I also don't go out and start it often either; I roll it forward/back every couple months to keep the tires from getting flat spots, and I've started and drove it around about twice- but I let it fully warm up before I put it back.
