change from National 3.8 to Supercharged
Old May 18, 2016 | 08:49 AM
owens91's Avatar
Default change from National 3.8 to Supercharged
So I've been thinking that I may want to make my car super charged, I've been wondering how hard is it to do and what all is needed?
Old May 18, 2016 | 09:08 AM
Thumbs up >POWER Corrupts & Makes U go faster<
Hi George,
How many miles on your Monte ? What condition is your engine & Transmission ?
Supercharger for my 01 - Monte Carlo Forum - Monte Carlo ...
Click & Good Luck
Old May 18, 2016 | 10:58 AM
Everything from the heads up from an L67, axle work, some engine harness additions, and PCM tune.
Dead set on an L67 top-swap? What about going through GP forums and seeing if you can score a used turbo kit from a demod?
Old May 18, 2016 | 11:20 AM
nitehawkjcb's Avatar
^What he said, didn't think axle work was needed with a top swap though.
Old May 18, 2016 | 12:43 PM
owens91's Avatar
Not dead set but exploring options
Old May 18, 2016 | 01:39 PM
Yeah, IDK why I said the axle work, keeping the bottom end and transmission on the top-swap doesn't require the axle stuff.
I was typing a longer post, and then deleted out the middle of it. Probably was just an after thought of another sentence haha
The reason I mention the turbo, is the fact that it's really easy to bolt-on, doesn't require taking apart the engine, and I believe they are a touch easier to tune for.
Old May 18, 2016 | 04:10 PM
I hear ya. The tune is always the hardest part.
Old May 18, 2016 | 07:57 PM
shawn parker's Avatar
I'll keep a eye on this thread, I also want to make my 03 a sleeper
I use mine as daily so thinking I must save and plan a before/after all in one shot type upgrade ..... I can't mod as I go or until something breaks
Old May 18, 2016 | 08:59 PM
I'll second what is required mentioned above. You need the heads on up, the sc accessory pulley system, and the crank balancer. Plus whatever tuning you need (a canned vendor tune would be fine either way).
I also like the idea of a turbo setup, especially with how cheap some are getting.
It's really a tradeoff. An l67 top swap has the possibility of being far cheaper (I've seen it done under $500), but it is a lot of install work.
The turbo kit would be a much quicker install, but used kits start about $1500, or you're nearly $3k for a new setup.
Old May 19, 2016 | 09:17 AM
I'm honestly at the point of my build that I wish I went with the turbo. This whole thing has been custom this, and custom that. I can't even get some parts from ZZP anymore.
