Cat removal O2 & wideband location?
Old Jan 10, 2013 | 11:32 AM
Ace25's Avatar
With all due respect, I don't think an O2 emulator will work on my 2005.
ZZ has them here, but only list a 2000 - 2003
Easy Performance - O2 Emulator #EP-O2SM-GM01
They also mention this:
The second oxygen sensor is located after the catalytic converter and is used only to detect the performance of the converter. The PCM does NOT use any data from the secondary O2 sensor for engine management. The PCM will set an SES (service engine soon) light (for P0140, P0141 and/or P0420) if the catalytic converter is removed, the sensor is removed, or the sensor goes bad.
I have HP tuners, so disabling the codes is a non issue and I tried that. My Long Term Fuel Trims were REALLY high without the rear O2. I think I have to agree with ChibiBlackSheep that there are more parameters being read by that rear O2...
dgm
Feb 12, 2015 08:30 PM
Bait
Mar 11, 2013 11:42 PM
kicker
Apr 2, 2011 09:41 AM
BeachBumMike
Jul 14, 2007 04:19 PM
