belt chirp noise
Old Feb 13, 2012 | 06:52 PM
dave countie jr's Avatar
Default belt chirp noise
hi kids, long time no post. had some family issues. I m STILL having that belt chirp noise in my 04 3800 series 2. i changed the ABT 3 times and the belt twice,no luck. After the engine gets warm it shuts up.... sometimes. I dont know what else to try. its driving me fruit!
Old Feb 13, 2012 | 06:57 PM
DRuben's Avatar
Think its the waterpump? Pulley? I tried this old trick on my truck where you take some brake fluid and pour it on the belt and if it immediately gets quiet its the belt and if it doesnt its the ???bearings???. Well mines got quiet and sure enough when I changed the belt no more sqeak...
Old Feb 13, 2012 | 07:17 PM
Mike 00LS's Avatar
This happens on ALL my chevys - it's annoying and loud as hell on my silverado - but the one part where the belt connects at (the piece at the bottom where you stretch it from...forget the term) is loose and shakes back and forth a bit - so that increases the squeak. On my Monte it only happens in the cold and it's not too terribly loud, but I'm sure that is just the old belt needs replacing.
Old Feb 13, 2012 | 10:34 PM
Have you tried to rotate each piece with the belt off. Maybe you can pinpoint the problem. If that don'e work you may want to get a mechanic's stethoscope(the kind with a metal rod on it) to see if you can tell where the noise is coming from.
Old Feb 14, 2012 | 02:29 PM
i'll try the brake fluid trick. but i heard not to contaminate the belt with anything. what the hell, if the belt is junk anyway so what. waterpump was done on the first abt job so i know it cant be that.
Old Feb 16, 2012 | 06:25 AM
monte07's Avatar
belt tentioner or idel pully. but when you have the belt off i would take a meatle brush ahd clane any pully thurolly that has groves on it to make sure that it didnt get any dirt or old matereal stuck on them to make a squeak. it happened to me when my water pump broke on my monte didnt clean the pullys because i didnt think there were matereal that was stuck on any of the pullys when i put on the surpintine belt
Snowcats95
Mar 5, 2015 06:10 AM
stryker221982
Sep 2, 2011 10:21 AM
GrandPaDave
Apr 20, 2009 11:51 AM
fedspunisher
Nov 12, 2006 06:52 PM
tundra
Aug 15, 2005 05:24 PM
