Bahdeets 07 Monte New Comp Turbo Installed
Old Jul 1, 2012 | 09:26 PM
  #31
Enzo354's Avatar
STILL SLOW
Not sure how I missed this. That car is amazing.
Old Jul 1, 2012 | 10:11 PM
  #32
BlackRainSS's Avatar
Thats one hell of a beast!!
Old Sep 4, 2012 | 07:14 AM
  #33
Bait's Avatar
Anymore updates?
Old Oct 8, 2012 | 09:44 PM
  #34
Monte SSV's Avatar
Car is near complete. A lot of updates, mostly rework to things that either I did not like or just wasn't working. 2 big issues left. Front end is slamming/crashing when I hit a bump over 20 MPH. All new LCA's. Could be the issue. My tech thinks its the change in cradle geometry causing the banging, cradle has been lowered. Has to put a scope to several areas when driving and try and reproduce sound and exactly where it is coming from to fix. The other issue is cooling. Running 205 F / 195 F on the highway and the fans do not shut off. Airflow needs to be re-directed or more air flow needed - my tech is in the middle of doing that now. Rear suspension reworked to fit larger tires. Dash reworked and repaired. Redoing again to use dual gauges for more monitoring. New front end (Impala). Hood vents installed ('94 GTP) may need NACA's vents also not sure. Tranny pan spacer installed. New BHJ damper installed. Larger Turbo installed. Water tank & ice box in trunk for intercooler. Oil accumulator installed, remote battery shut off installed. New 150/170 AMP alternator installed. Exhaust recoated. New LED platium tailights/Depo heatlights. Leather shift ****. Drivers racing harness. Fire extinguisher. New Waldon fuel pump. Final dyno numbers 814.8 WHP. Lost 8 HP with 2 rerouted header tubes due to melting plug wires. Line lock installed on both rear wheels - single covered switch at shifter. Lots more - too much to remember - any questions ask. Thank you for the interest. Got to meet XR7supercat - great guy. Our cars look like twins, his is '06 & mine is an '07
Old Oct 8, 2012 | 09:48 PM
  #35
01 Monte SS's Avatar
We need pictures!!!!!!!!!!!!!!!!
Old Oct 10, 2012 | 09:52 PM
  #36
Hiroska's Avatar
Holy batman. I admire you sir.
Old Oct 12, 2012 | 01:10 PM
  #37
KingRenz's Avatar
My HERO!
ZIPPY02
Aug 2, 2022 07:01 AM
ZIPPY02
Dec 9, 2012 05:32 PM
joeykl66
Oct 28, 2012 05:34 PM
MillerMonteSS
Oct 2, 2011 09:33 PM
