anyone read my tune?
As said above- if you're 11.3 AFR at the shift point, I don't see how you could be running out of fuel- due to the pump or filter. If you were starving for fuel for some reason- that AFR should be going leaner (ie heading towards 13s, 14s AFR at WOT).
I hope you get it sorted. Again, how much KR are we talking about here? Are you sure it's real KR and not torque management (which shows as KR when your scanning)?
dunno if it will be any help, but my narrowband 02 reading from my aeroforce gauge shows 14.70 almost all the time.
well, then i dunno what to do.
you guys say my fueling is fine, so im gonna stick with it. not gonna replace the pump, maybe just get a new filter and test it. see if maybe i just got a crappy filter.
im gonna go with an intercooler. 9LB's of boost is a lot more that i expected to make. maybe its too much for my setup now, and an intercooler will kill the KR. im gonna try that. i was planning on intercooling it since i got the supercharger, so this kills 2 birds with one stone (hopefully).
if this doesnt work, im gonna check out the fuel system next. turbo tim says that the L36 pumps are pretty weak for supercharged systems running decent boost w/ 33LB injectors.
on another note, could the cold starts im seeing be caused by a bad flash on my pcm from zzp? i have a 72mm TB that runs a 98 MAF. what if they flashed it for a 99 and up MAF? could that have anything to do with my cold start misfires and RPM's going up/down? only happens for like 30 seconds though.
how could i tell if it was just torque management?
For example, the first time I did a burnout in my SS M90 car my car immediately jumped to 5 and then to 9- thought I blew something up- later I realized it was just torque management doing it's job.
You really need HP Tuners. It'll make this whole process SO much easier for you.
good to know about the torque management. imma have my shop check that out, and also check if the pcm settings that zzp did match whats actually on the car. my shop is doing the tuning using HP tuners. i'll ask them about it all.
the 11.13AFR is from the dyno run. i believe that was after they did the initial tune to it.
14.70 is what my narrowband o2 says almost all the time when driving, but at WOT it starts going lower, into the 13's. I have yet to see the scan from the tuner to see what my o2 values are
im curious about that torque management because my shop changed the tune a little so i wouldnt see so much KR, so its not at its peak right now. if thats the case, i should be seeing much better #'s.
In order for our help to be really 'helpful', we need some sort of scan data.
Once you get into power enrichment (PE)- which should happen at 35% TPS at MOST for a boosted L36- you should be in the 11s AFR wise. If your WOT and still in the 13s AFR, then you've got fuel problems.
the dyno scan is the only scan i have, but you are more than welcome to read it. i will have to email to you both though, scan depot isnt set up for this type of scan. PM me your email addy's and i will send it out to you. i promise no spam! haha.
im trying to get my other scan from my shop, he's just been a little busy. He would send me the scan from the HP tuner. thanks guys.
Took a look at your tune...I wish there were a few more columns (TPS %, cylinder airmass, injector duty cycle, some others), but I think it was VERY clear that you are NOT running out of fuel! You are running super rich at WOT from what I could see.
hmmm, ok thanks.
just got the intercooler yesterday, got the heat exchanger installed working on the rest next. thanks for everything guys, keep ya updated after the intercooler gets fully installed
07ss_ls4
13
05-09-2014 12:17 PM
ChibiBlackSheep
19
08-20-2011 09:22 AM
03, afr, bbv, can, carlo, catch, install, m90, monte, narrowband, o2, optimal, supercharged, supercharger, unhooked
