Another update!
Its Alive!!!!!!!!
After a hiccup figuring out the spark plug wire layout to the coils, I finally started it and let her idle for a bit. After tommorrows oil change, it will be drivable again.
No codes.... engines not making any unusual noises... a huge relief!!!!!
Side notes:
The issue i had im my previous update with the fuel leak turned out to be the return fuel line washer... after i replaced it with a new one, i was good to go.
I replaced the fuel pressure regulator while i was there. im pulling 55 ish with the key on engine off.
The idle is drastically improved, maybe due to the cleaned tb or fresh plugs and wires or fpr.
Old spark plug 1 has a readish hue to it. Makes me wish i would of done the headgaskets while i was there, but i was scared of tearing out more of the engine without ever doing this.....
I didnt keep track of the layout to the spark plugs and coils. really wish i would of labled and wrote down to save the headache of it not sarting.
Next weekend after i drive her for a bit, ill throw in the coi, and new coils. also get a new fuel filter....
Side notes:
the wizaired is what i will be putting in. the coils right now are stock but i got new supercharged coils, cant remember what engine they are for... im still waiting for my new t stat and 65mm tb from mizzy, but im getting impatient after waiting almost 2 months now. also i forgot, i have a new downpipe with u bend delete hidden in the basement from my wife. that may go on next weekend too.....
my current mods are now a ported upper and lower intake manifold...
you're hiding parts from your wife? lol
they are the l68 (?) coils, from a supercharged 3.8.. from what i have found on here so far, they will help us 3.4 guys put a more reliable spark at higher rpms. I have to not let my wife know about the mods to my daily driver and kid hauler.
