addin some power
Old Sep 18, 2008 | 01:33 AM
Havok0180's Avatar
Default addin some power
Hey,
I'm new to the forum. i have a 1999 monte carlo z34 with a 3800 II. I want to give it some more power and maybe add some style to it. any ideas would be much appriciated!
thanks
Old Sep 18, 2008 | 06:14 AM
mrl390's Avatar
Default RE: addin some power
Welcome to the forum.
check out:
www.zzperformance.com
They have alot of stuff for the 3800 monte carlos and grand prixs.
Old Sep 18, 2008 | 09:56 AM
You need to be a lot more specific- especially as far as your budget goes, and also how extensive do you want to get into modifications.
The engine/transmission has a lot of options- you can take it from your stock NA ~160whp setup to a 500+whp 10 second car if you put enough into it.
As far as appearance goes, there is one full body kit available, a handful of ground effect packages, obviously rims, spoilers, etc etc.
But without more specifics, its hard to point you in any direction.
Old Sep 18, 2008 | 12:16 PM
Havok0180's Avatar
well i want it to still be street legal and my budget isnt huge but i can put a good amount of money into it
Old Sep 19, 2008 | 12:25 AM
Still isn't very specific, you can do 500+ to the wheels and still be totally street legal- not to mention, you didn't specify if you want to put the money into going faster or looking better.
Also, it would really help if you had a general range of what you're looking to spend- a good amount of money to a high school student could be $1000. A good amount of money to someone working a real full time career job could throw $5k+ and not think its crazy- too many different possibilities without being more specific.
Old Sep 19, 2008 | 01:55 AM
Havok0180's Avatar
ok well i plan to put most of the money into going faster so i dont end up looking like some young idiot who has a nice car thats all show and no go. i work full time so i would say that over all i would probly put $4000 at about the limit. im not totally against going over that but i would rather keep it under 4.
Old Sep 20, 2008 | 12:20 AM
One option would bea used turbo kit, and saving the rest for tranny mods.
The other option would be an L67 top swap, which could be done for about $1k- do a cam, IC, and some headers (used if you can find them)- for another $1500-2k, then a smaller s/c pulley and save the rest for trans mods.
Its kinda up to you how labor intensive you want to get- but if you do it properly, $4k should get you over 300 whp- at which point you do need to be thinking about tranny upgrades.
Old Sep 23, 2008 | 12:13 AM
Havok0180's Avatar
well that helps a lot! thanks but do you know what kind of mods i can do to trans?
Old Sep 23, 2008 | 12:51 AM
go to www.zzperformance.com under grand prix, under transmissions
if you just do a straight IC turbo kit- you should be ok, but just realize that the more you get into modding once you're boosted- the shorter the life of your stock trans.
I will tell you the major problem areas with big power 4t65 setups are the input shaft and drive chai.
Old Sep 25, 2008 | 01:55 AM
Havok0180's Avatar
alright cool. well i definatly appreciate your help!
