700r/28"tires/410 gears
Old Jan 5, 2013 | 08:34 PM
cxt35's Avatar
Default 700r/28"tires/410 gears
Anyone running something close to this: 700r tranny with a around 355 cubic inches, 28" tires, and 410 posi gears.
If so what are your rpms like in town and highway i need to know, i am getting a 700r early fall. Now i have a turbo 350 with a shift kit and 2500 stall torque converter engine is beefed up a little i have a performance cam, headers, eldebrock aluminum intake, etc. YOU CAN IMAGINE MY RPMS NOW
would this be a good set-up. my purposes are daily driver but about 5 miles to and from each day plus highway driving very minimal, i just want to be able to go to my home town 90 miles away if i choose too or basically be able to cruise worry free with my low gears. ANY AND ALL INFO WILL BE GREATLY APPRECIATED.
Next week i am getting a performance radiator/fan and 18" trans cooler to keep me cool in the meantime. thanks in advance
Old Jan 5, 2013 | 09:10 PM
Bait's Avatar
In your subject you say 28" buy in your post you say 18". Looking to clarify.
Old Jan 5, 2013 | 10:21 PM
CDN85MonteCarlo's Avatar
Here is the formula for figuring out rpms at speed and stuff
Rpm = mph x gear ratio x 336
Tire diameter
Mph = rpm x tire diameter
Gear ratio x 336
Gear ratio = rpm x tire diameter
Mph x 336
Tire diameter = mph x gear ratio x 336
Rpm
and a 700r I think has a 30% underdriven OD ...so your rpms will be 70% of your final speed.
Example MPH= 60mph x4.10 x 336 =82656
divided by tire diameter 28" =2952 rpms at 60
NOW! since your 700r is an OD..and 4th gear is .69..multiply 2952X .69 to get final rpm =2036RPM at 60 mph
Old Jan 5, 2013 | 11:20 PM
cxt35's Avatar
thanks cdn85 monte carlo. help ALOT
Old Jan 5, 2013 | 11:22 PM
cxt35's Avatar
and bait im not sure what your talking about? in my subject and post my tire sizes are different? i don't get what you mean or what you are asking... its pretty clear what i am asking 700r 410 gears and 28" tires...
Old Jan 5, 2013 | 11:24 PM
cxt35's Avatar
at the end of my post i mention an 18" trans cooler thats about all that has to do with 18 inches PAL.
Old Jan 6, 2013 | 01:09 AM
It doesnt matter about anything else..if you have a 28 inch tire, with a 4;10 rearend, at 60 mph, you should be turning a little over 2000 rpm, with a 700r..trans, taking into account that high gear in the 700r is an overdrive gear..NOT! 1-1...but approx .69-1 (if I remember right)
The 2500 stall converter will allow a bit more oomph on takeoff
Sounds like a nice engine setup..you should have no problems on the highway.. or around town..
All the formulas I gave you, are basic math...just plug in the KNOWN numbers, and you will get what you want
glad i could help, if you have any more probs, there are a LOT! of more experienced guys on here who may be able to explain it better..
Old Jan 6, 2013 | 01:18 AM
And if you keep the turbo 350...your rpms will be 295o approx at 60 mph..kinda buzzy..lol..700r would be better, or swap to a set of 3;73s or 3;42s in the rearend,,with the 2500 stall, it would work better imo...rpms would drop at 60 mph..
Old Jan 6, 2013 | 02:15 AM
Enzo354's Avatar
STILL SLOW
Old Jan 6, 2013 | 03:58 AM
cxt35's Avatar
Thanks CDN85 Monte carlo it does help alot and i appreciate it. I doe have other posts on here regaurding this subject and honestly so far your advice has been the most accurate and helpful, Thanks
